Hard Drive 1 vs Hard Drive 2
Post Date: 2011-06-12
Grape View Drop Down
  Quote Grape Quote  Post ReplyReply bullet Topic: Hard Drive 1 vs Hard Drive 2
    Posted: 12 Jun 2011 at 4:20pm
I have two drives: one for games, OS, etc and the other for Data. I quickly learned just by adding Total War Napoleon and Windows Office, that I almost got up to 50% of the 120 GB hard drive space for Hard Drive Set 1.
Should I have, or could I have installed Office for Windows on Hard Drive Set 2? I am thinking of when I add other games that space will become a premium, or am I panicking for no reason?
thx
Digital Storm Velox
Intel Core i7 6700K 4.0GHz
16GB DDR4 2666MHz Digital Storm
750W EVGA SuperNOVA
1x GeForce GTX 1080 8GB
500GB Samsung 850 EVO
Western Digital/Seagate 1 TB
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 12 Jun 2011 at 5:06pm
ive got an SSD as my primary drive also with a 1tb black like you.  I still havnt put any games on my SSD because of taking up alot of space.  WIthout getting into numbers there will be a difference in load times but to be honest no game ive ever played on my pc has made me go wow i wish i installed this on my SSD instead of the black.  I had lord of the rings online put on my black at one point and the loads still happen within seconds.
maxyme View Drop Down
  Quote maxyme Quote  Post ReplyReply bullet Posted: 12 Jun 2011 at 5:11pm
you want a ssd as your primary drive since it will boot windows in less than 15 seconds :)
Steam:pcmaster160
  Quote Grape Quote  Post ReplyReply bullet Posted: 12 Jun 2011 at 6:51pm
I have the SSD as my primary drive for the OS and Games. Am I able to install Microsoft Office on the secondary drive then, thus freeing up space on the SSD? I will then be able to operate MS Office in the general manner?
thx
Digital Storm Velox
750W EVGA SuperNOVA
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 12 Jun 2011 at 6:53pm
thx
did u read my post? the answer is yes
  Quote Grape Quote  Post ReplyReply bullet Posted: 12 Jun 2011 at 6:55pm
thx
Oops <ducks>
Thanks
Digital Storm Velox
750W EVGA SuperNOVA
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Jun 2011 at 2:37am
You can fill up your ssd pretty much, its not like a hdd don't worry about it.
I would not install games/apps that use regkeys on a different hdd, if your hdd 2 goes bad, you will need to reinstall everything on that hdd.
ssd do more then just load games faster, they take care of performance stutter you don't realize is from hdd, and they bring better min fps depending on the games:
in the above chart you see the game, the red on top is veloci raptor and the blue is x25 intel, you see the improvement, the intel 320 is even better then the x25.
at the end of the day all apps/games will benefit from ssds speeds, and not just from loading, that is why we told you to get the ssd, so that you can put os/apps/games on it.
ssd helps with load times yes, but there are also many other areas it helps, read/write/seek, these will all make a difference and why we recommend getting a ssd and putting os/apps/games on it, otherwise we would recommend a 40GB ssd for the os and tell you gusy to put the rest on the hdd.
you are at only 50% on the ssd, you got plenty of room left, use it.
Edited by DST4ME - 13 Jun 2011 at 2:43am
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 13 Jun 2011 at 1:39pm
i dont see any freezing and hitching on my system what so ever. So when people use crappy 1tb 50$ drives as a main theyre gonna see horrible freezes and hitches? i dont think so
Dragoonseal View Drop Down
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 13 Jun 2011 at 2:16pm
It depends largely on the game, there are some that have the really bad habit of constantly loading new content on fly from the HDD instead of doing it ahead of time, creating hitching and FPS drops. Games that come to mind on this are Crysis and the STALKER series, they constantly stream from the HDD in the middle of play, and it's very noticeable.
I don't have them on hand, but I've seen some minimum FPS comparisons for Crysis and they are significantly higher on a SSD versus a HDD. And with the STALKER series I can tell you from first hand experience after almost 600 hours of game play between the three games (about half of which was on HDDs, half on SSDs) that they are absolutely notorious for hitching and outright freezing for long periods of time when loading data when approaching some areas (and will happen each and every time you cross said areas). There's still a bit of it even on a SSD, but the frequency and severity of it is remarkably reduced compared to on a HDD.
I'm a very impatient person, and as a very active gamer frequent and/or long load times will just drive me completely up a wall, I can't stand them. SSDs were probably the best thing to happen to games in a long time, I will never go back to having games on a conventional HDD. Hahaha
Lilim
Intel Core i7 920 @4.2GHz
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 13 Jun 2011 at 2:38pm
It depends largely on the game, there are some that have the really bad habit of constantly loading new content on fly from the HDD instead of doing it ahead of time, creating hitching and FPS drops. Games that come to mind on this are Crysis and the STALKER series, they constantly stream from the HDD in the middle of play, and it's very noticeable.I don't have them on hand, but I've seen some minimum FPS comparisons for Crysis and they are significantly higher on a SSD versus a HDD. And with the STALKER series I can tell you from first hand experience after almost 600 hours of game play between the three games (about half of which was on HDDs, half on SSDs) that they are absolutely notorious for hitching and outright freezing for long periods of time when loading data when approaching some areas (and will happen each and every time you cross said areas). There's still a bit of it even on a SSD, but the frequency and severity of it is remarkably reduced compared to on a HDD.I'm a very impatient person, and as a very active gamer frequent and/or long load times will just drive me completely up a wall, I can't stand them. SSDs were probably the best thing to happen to games in a long time, I will never go back to having games on a conventional HDD. Hahaha
yea in cases like these i can totally understand. It really brings out another point of how developers can make these games have it flawed in such a extreme way.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Jun 2011 at 1:37am
As dragoon mentioned not all games are the same, perhaps you don't see it for your use, but it does not mean others won't with other games.
Personally just on performance form os/apps, I would not go back to hdd either, and I don't even have the best ssd yet, lol.
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 14 Jun 2011 at 1:40am
of course. my key critial programs like photshop etc are all on the ssd :D
