Hard Drive Addition - OEM or Retail
Post Date: 2009-04-30
mhalfon View Drop Down
  Quote mhalfon Quote  Post ReplyReply bullet Topic: Hard Drive Addition - OEM or Retail
    Posted: 30 Apr 2009 at 5:20pm
Hello All,
I am planning to add a hard drive to my new DS machine (HAF/750W/i7920).
Question is do I need to order a retail kit or OEM?
Thanks in advance
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 30 Apr 2009 at 6:17pm
does not matter, as long as its an sata II you are good to go
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 30 Apr 2009 at 6:40pm
What are you going to use the drive for? I can help you pick a drive, if you let me know what you want out of it.
OEM will be just a hard drive, retail is the same hard drive, but comes in a box, with a manual, screws, cable.
  Quote mhalfon Quote  Post ReplyReply bullet Posted: 06 May 2009 at 4:58pm
It will be an internal drive to back up several hours of HD video, music and photos.
Thanks
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 May 2009 at 5:09pm
if its storage then why raid? back up needs to be on a different HDD then the OS drive and its best to be on one drive, cause in raid when one drive fails you lose all data and with 2 drives now your chances of something going wrong has doubled.
Edited by DST4ME - 06 May 2009 at 5:11pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 06 May 2009 at 5:21pm
This is an excellent drive for HD storage http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
 continious read and write speed right at the speed of a Velociraptor. 2Tb drives are too much $$ at the moment.
