Hard Drive Issue and Windows Issue
Post Date: 2013-02-08
aceland View Drop Down
  Quote aceland Quote  Post ReplyReply bullet Topic: Hard Drive Issue and Windows Issue
    Posted: 08 Feb 2013 at 5:46pm
Lately every few weeks when I power up my computer it fails to load into windows. It hangs once it gets to the blue spinny circle part. I have to boot into safe mode and do a restore to an earlier date to get windows to boot up.
I downloaded HD Tune application and this is what is shows for my storage mechanical drive:
HD Tune: ST31000333AS Health
ID                               Current  Worst    ThresholdData       Status
(01) Raw Read Error Rate         111      99       6        36735611   Ok
(03) Spin Up Time                93       87       0        0          Ok
(04) Start/Stop Count            70       70       20       31316      Ok
(05) Reallocated Sector Count    99       99       36       56         Ok
(07) Seek Error Rate             77       60       30       108467895  Ok
(09) Power On Hours Count        94       94       0        5878       Ok
(0A) Spin Retry Count            100      96       97       37614      Failed
(0C) Power Cycle Count           70       37       20       31407      Ok
(B8) (unknown attribute)         100      100      99       0          Ok
(BB) (unknown attribute)         70       70       0        30         Ok
(BC) (unknown attribute)         100      98       0        1310758    Ok
(BD) (unknown attribute)         1        1        0        205        Ok
(BE) Airflow Temperature         75       41       45       487653401  Ok
(C2) Temperature                 25       59       0        25         Ok
(C3) Hardware ECC Recovered      43       26       0        36735611   Ok
(C5) Current Pending Sector      100      100      0        0          Ok
(C6) Offline Uncorrectable       100      100      0        0          Ok
(C7) Ultra DMA CRC Error Count   200      200      0        1          Ok
Power On Time         : 5878
Health Status         : Failed
Can anybody explain what this spin retry count is and if this failure is contributing to my problems with Windows? Also, Windows is installed on a seperate SSD drive not the mechanical drive that has the failure.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 10 Feb 2013 at 3:04am
Hi aceland...   I'm a little late to this.   Got buried in 34" of snow.
The spin up faults sounds like the drive might be failing.    I would back up anything you want.    Also check your power connection to eliminate a lack of power causing it to spin up too slow.
The reasnon OS on SSD still causes a problem is because on boot, files you have on the HDD also load, not just Windows.
Not much else to do that I know of.    Good luck.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 10 Feb 2013 at 3:12am
remove/disconnect the hdd and see if the pc boots off of the ssd just fine with no errors, if so then your hdd has a problem, you should clone it to a new hdd just incase, it could be on its way out.
hddtune can sometimes report false stuff but since you are having problems and hdd tune is indicating errors, I would clone just to be safe.
spin retry count, is basically hdd tune telling you it took this many times to get the dist to finally spin and work at full speed, so for example if on first try hdd tune got the disk to spin at full speed then you get zero for that value, but if the first spin did not achive full speed, then hdd tune trys again and finally on the 20th try it gets full speed, then the value for "spin retry count" would be "20".
Now as you can see yours is reporting that it can never get the disk to run at full speed no matter how many times it tried.
you can follow my clone guide here
