Hard Drive Question
Post Date: 2010-07-08
Mouseguard View Drop Down
  Quote Mouseguard Quote  Post ReplyReply bullet Topic: Hard Drive Question
    Posted: 08 Jul 2010 at 8:50pm
Greetings all,
I was looking to upgrade my "storage" drive from 500 gb to possibly (2) 1 TB 64mb cache, hard drives in a raid 0, since I will load some games, since my OS drive is a corsair 128 gb SSD, which I would like to take the games off that drive.  Would it make sense to buy another SSD or 1 or 2 TB drive(s).  Any suggestions, opinions would be appreciated.
Thanks in advance,
Mark
Baby Bear
Corsair Air 540
i7-6700k @ 4.5 gHz
Asus Maximus VIII Hero
16 gb 2666 MHz ram
Corsair HX1000i
800 GB Intel 750 series NVM-e
Noctua NH-D15 Cooler
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 08 Jul 2010 at 9:58pm
when you say would it make sense, what do you mean by that
do you feel like your system is actually slow and needs this change?
dragoon will jump on you for picking corsair over intel ssd, ill tell you that much
to me if your going for storage stay away from raid, youre cutting your space in half, if you have stuff that sensitive you need a hard copy imo
  Quote Mouseguard Quote  Post ReplyReply bullet Posted: 09 Jul 2010 at 3:20pm
I have an external drive which I keep all my sensitive material on, so I would say I want a bit more performance from my drives.  I got the Corsair when I had DS make my rig last July, just want to speed it up a bit, plus expand on the storage, if that makes sense, thanks for the input !ender
Baby Bear
Corsair Air 540
i7-6700k @ 4.5 gHz
16 gb 2666 MHz ram
Corsair HX1000i
Dragoonseal View Drop Down
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 09 Jul 2010 at 4:03pm
If you want fast get Intel SSD space. You just can't get HDDs fast even with RAID setups, they don't scale well. But games in general don't benefit from even SSD speeds very much (some do more than others), so you're probably not going to get much of a benefit one way or the other.
Lilim
Intel Core i7 920 @4.2GHz
  Quote Mouseguard Quote  Post ReplyReply bullet Posted: 11 Jul 2010 at 1:06am
Thanks Dragoon...I think I will just pick up a plain old 2TB drive for my storage issues, and will keep an eye on prices for a SDD upgrade =)
Regards!
Baby Bear
Corsair Air 540
i7-6700k @ 4.5 gHz
16 gb 2666 MHz ram
Corsair HX1000i
This page was generated in 0.1025391 seconds.
