Hard line water coolingPost Date: 2019-10-15 |
| Author | |
GunslingerN7
Joined: 10 Oct 2019 Online Status: Offline Posts: 8 |
Topic: Hard line water coolingPosted: 15 Oct 2019 at 5:03pm |
Does the hard line water cooling have the quick disconnects
HockeyBuck
Joined: 27 Jul 2012 Online Status: Offline Posts: 1608 |
Posted: 15 Oct 2019 at 7:44pm |
Welcome to the forum GunslingerN7!
These days yes, DS is now mounting QD’s on the hard line tubing. That said, you should be aware that when we do hear of leaks on the forum, it’s almost always the hard line tubing. There’s no flexibility, so it doesn’t handle shipping bounces very well...lol.
hoserator
Joined: 08 Oct 2014 Online Status: Offline Posts: 7966 |
Posted: 16 Oct 2019 at 12:43am |
All the above but it does look super. And in the likely event that you keep your system long enough and you want to upgrade [usually the gpu(s)] you will most likely have to redo the hardline.
GunslingerN7
Posted: 16 Oct 2019 at 3:00am |
Can I change my order and have soft clear tubing and fluid used instead
Cretae
Joined: 22 Mar 2010 Online Status: Offline Posts: 7331 |
Posted: 16 Oct 2019 at 4:40am |
Absolutely.
GunslingerN7
Posted: 16 Oct 2019 at 5:06am |
How can I go about doing that
HockeyBuck
Posted: 16 Oct 2019 at 10:39am |
Call DS and talk about that with DS Sales...soon as you can. They are easy to work with on changes....
ThePinkGoat
Joined: 06 Oct 2010 Online Status: Offline Posts: 174 |
Posted: 16 Oct 2019 at 10:50am |
I would also like to mention sometimes the pumps give out, new or old. Be ready to work on your tubes down the road, at some point you will need to swap parts.
GunslingerN7
Posted: 19 Oct 2019 at 12:14pm |
I figured that No system is perfect and water cooling is more complex than air cooling and requires maintenance like flushing and changing the fluid. I appreciate the input this will be the most complex water cooling loop I have ever had. Do they build in a drain port or give any thought to maintenance when they put the loop together?
hoserator
Posted: 19 Oct 2019 at 12:29pm |
Unfortunately no and you can special order one, which we suggest when an open loop is ordered. Haven't seen one. If and when you call to change to soft tubing do request that a drain valve be installed and an extra bottle of coolant. During shipping, air will come out from the system and you will want to refill. ![]() Edited by hoserator - 19 Oct 2019 at 12:34pm |
