Hardlock and Loud Noise
Post Date: 2008-07-31
Riven View Drop Down
  Quote Riven Quote  Post ReplyReply bullet Topic: Hardlock and Loud Noise
    Posted: 31 Jul 2008 at 1:35pm
Since I received my computer I have been having issues with periodic hardlocks, sometimes with a loud noise through the speakers and other times without.  I have tried everything that I can think of and need some help...I have disabled the sound card and still gotten hardlocks (without the noise).    I received it OC'd and returned everything to factory specs and still had the issues.  I have run stress tests at stock and OC'd sometimes with hardlock, and other times without issue.  Then the other day when I was trying to boot up the computer after it had hardlocked with the loud noise,  it wouldn't load Windows saying that there wasn't an OS installed.  I re-installed the OS and booted it back up, just to have it hardlock twice when I was putting everything back to the way I wanted it (specifically turning off Vista Extras and installing Live Onecare).  I have read about several other people having the same issue with the SB X-Fi card and Vista64, but I think that would only be the cause of the hardlocks with the noise (turning off my speakers cuts off the noise).  Any help would be appreciated!  Let me know if you need more info!  Below is my rig:
Q9450
790i Ultra (BIOS 6.0)
4GB DDR3 Corsair 1600MHz
2x 8800 GTX SLI (Driver: 175.19)
Liquid Cooled CPU
Vista Ultimate 64
Creative SB X-Fi Xtreme Gamer
Edited by Riven - 01 Aug 2008 at 11:22am
Kliebor2 View Drop Down
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 31 Jul 2008 at 1:38pm
If you want to validate that remove the sound card and try rebooting, if the sound card out is enough to stop the issue then you know the problem.
After that you need to decide what you want to pursue.
DaveStar
Dual PNY OC2 GTX 560Ti
8 Gigabytes DDR2/800
  Quote Riven Quote  Post ReplyReply bullet Posted: 31 Jul 2008 at 1:45pm
I tried it with the SB X-Fi disabled and it was still having the issues...wouldn't that be the same as if it was out?
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 31 Jul 2008 at 1:48pm
No.
Disabled is not the same as out. I have had cards with bad components cause a short or other electrical problem, which will not be rectified by disabling the hardware
Dave Star
Edited by Kliebor2 - 31 Jul 2008 at 1:49pm
  Quote Riven Quote  Post ReplyReply bullet Posted: 31 Jul 2008 at 1:52pm
I didn't think about that!  Will do when I get home then.  I'll post my results when able.
Thanks
Edited by Riven - 31 Jul 2008 at 1:53pm
  Quote Riven Quote  Post ReplyReply bullet Posted: 31 Jul 2008 at 9:23pm
Alright, well, that still doesn't fix it.  I took out the SB X-Fi, unistalled all the drivers and set up the mobo sound =/  Still got the hardlock 1 min in the game with the noise again...not quite the same but similar...
Edited by Riven - 31 Jul 2008 at 9:27pm
TomD View Drop Down
  Quote TomD Quote  Post ReplyReply bullet Posted: 01 Aug 2008 at 2:09am
Since the sound card removal didn't work, my next guess would be RAM.
1. Make sure your RAM is set to its rated speeds, 2T command rate, and proper voltage in the BIOS. The 790i board doesn't default the command rate and voltage settings correctly. Set the RAM to manual - "optimal" settings will incorrectly default to 1T.
If that is already set correctly or doesn't solve the issue:
2. Remove and reseat the RAM.
If that doesn't work...
3. Run Memtest to see if the RAM gives errors (or you could do this first)
If Memtest gives errors you need to replace your RAM, if it tests ok it maybe be a motherboard issue with handling the RAM which can be determined by:
4. If you have 2GB sticks, try putting them in the other set of RAM slots. If you have 1GBx4 try removing two sticks and trying both sets of slots
5. Try just one stick of RAM
790i boards can be picky about RAM sometimes even if memtest shows no problems.
Good luck!
  Quote Riven Quote  Post ReplyReply bullet Posted: 01 Aug 2008 at 8:45am
I have my RAM set to its rated speed (7-7-7-21,2T: 1600MHz - 1.9v)...I have run Memtest without any errors as well.  I will try moving the 2GB sticks to other slots this afternoon.  Again thanks for the tips!
TomD View Drop Down
  Quote TomD Quote  Post ReplyReply bullet Posted: 01 Aug 2008 at 11:52am
You got a bad HDd as it would not see your OS...
You got something there, I read right over that part and just focused on the BSODs and hardlocks.
  Quote Riven Quote  Post ReplyReply bullet Posted: 01 Aug 2008 at 6:05pm
I don't think it is my HD, everything loaded up fine agian after it happened.  I think the OS just got corrupted from the hardlocks.  I got home today and have not had an issue yet (fingers crossed) with no changes since last night.  I don't know what is going on.  I have read some people have issues when they turn SLI on, so I turned it off when I first got on and when it was working fine for 2 hours decided to try it with it back on...still no locks after another hour...YEEHAW!  Of course I am ready for it to lock any second now =/
The only thing that I haven't done is load the sound card drivers back on, but I don't think it is that since after I took out the X-fi card and it still happened.
Is it still an HD problem possibility?
Edited by Riven - 01 Aug 2008 at 6:16pm
  Quote Riven Quote  Post ReplyReply bullet Posted: 01 Aug 2008 at 7:00pm
Sure thing!!!  I tried going back one driver on the 8800GTXs, but that was when I was still getting the locks...was happening with both!  I don't know, this has all been real strange!
Thanks for all the help!!!
  Quote Riven Quote  Post ReplyReply bullet Posted: 01 Aug 2008 at 10:46pm
Still working fine for now! No I haven't, but I will check them out!
TomD View Drop Down
  Quote TomD Quote  Post ReplyReply bullet Posted: 02 Aug 2008 at 12:46am
Have you tried downloading and running Prime95 and running the torture tests?
If your computer is having any sort of stability issues, it will usually bring up a BSOD or hardlock pretty quickly.
32-bit version
64-bit version
  Quote Riven Quote  Post ReplyReply bullet Posted: 05 Aug 2008 at 10:18am
Alright, I haven't had anymore issues...yet!!!  I don't know what I fixed if it was anything =/
TomD...Yes!!! I use Prime95, Everest, and Memtest86 when OC'ing!!!
So, this is what I am working well with!!!
QX9450 @ 3.2/1600/1.25v
790i Ultra  9.64/BIOS 6.0/1.3v
4GB DDR3 Corsair 1600MHz @ 1600/7-7-7-20/1.9v (linked/synched 1:2)
2x 8800 GTX SLI 175.19/SLI Enabled (not OC'd again...yet!)
Creative SB X-Fi Xtreme Gamer (2.15.0006)
Corsair 1000w PSU
Liquid Cooled CPU
Vista Ultimate 64
SPP - 1.45
MCP - 1.55
