HD 5870 heat problem
Post Date: 2010-04-11
Ambidex View Drop Down
  Quote Ambidex Quote  Post ReplyReply bullet Topic: HD 5870 heat problem
    Posted: 11 Apr 2010 at 6:21pm
Hi
My Sapphire ATI HD 5870 is idle at 63ºC - fan speed at 21%.
(Reading from ATI Overdrive™.
My appartment has a lot of dust these days. I'm a student, so I don't clean 23/7 tbh.
Is it normal to have the idle temp at 63°C?
How can I clean the card for dust? Remove the red stock plastic fan cover?
THX
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Apr 2010 at 7:25pm
just remove the cover only and blow some air thru it, but why don't you set your fan higher?
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 11 Apr 2010 at 10:03pm
get some compressed air, remove the cover, and spray some CO2 lol
eh, you can put on a fan filter...it's a tradeoff for airflow, somewhat, but it greatly reduces the amount of dust that can get in your system every day. however, you'll have to remember to clean the filter too eventually.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 12 Apr 2010 at 12:51pm
How do I remove the cover? There are so many damn screws!
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 13 Apr 2010 at 11:52am
Hahahaha this is so funny! I turned on ATi overdrive and made it overclock my card.
GPU clock 890MHz
Memory Clock 1290MHz
Idle temp: 54*C. It dropped with overclock? OMG
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Apr 2010 at 4:30pm
Your fan speed got raised.
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 17 Apr 2010 at 7:43am
I have a problem. 1 of the screws was almost soft, so I kind of recked the tiny screw, so I can not get it out because I sort of sphered/rounded the screw socket. Do you have an idea how I can get it up? Do I have to drill the screw?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Apr 2010 at 6:21pm
As I told you, you should have never messed with the card and just raise the fans speed instead.
If you threaded the screws then now its gonna be a pain to get them off and if you have warranty you might mess it up if you try and drill them out and etc.
a gpu does not need cleaning unless you see its seriously dusted up or even with fan at 80% or 100% your temps are high.
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 17 Apr 2010 at 7:42pm
nvm the question lol T_T
I was asking about the screw thing, the warranty is irrelevant. IF I am making LCS I need to take it appart anyways lol...
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Apr 2010 at 9:21pm
yes if you are going to put a WB on it then you need to take it off. and you can drill it or get one of those kits that are for removing threaded screws.
