HDMI issues(plugged into correct port)
Post Date: 2020-06-17
BrennWhite View Drop Down
  Quote BrennWhite Quote  Post ReplyReply bullet Topic: HDMI issues(plugged into correct port)
    Posted: 17 Jun 2020 at 8:21pm
So I just received my Lynx today. I guess it would be Level 2 as it was the “better” option. I’ve tried everything I’ve seen on these forums so far but I can not get a signal to go to my monitor. I made sure I’m plugged into the HDMI video card port, not the moba port. I’ve tried every HMDI cable in my house(at least 5). I don’t know if it’s a BIOS issue or not but I can’t even get to the BIOS menu. I’ve tried resetting the CMOS by shorting the two CLRTC pins. The only thing left to try is to remove the battery from the motherboard but it’s behind my GPU and I’d really rather not have to do that. Any help would be immensely appreciated.
smfcpa View Drop Down
  Quote smfcpa Quote  Post ReplyReply bullet Posted: 17 Jun 2020 at 8:58pm
Sounds like a bad video port. Does the video card not have a display port you could try?
Edited by smfcpa - 17 Jun 2020 at 9:17pm
  Quote BrennWhite Quote  Post ReplyReply bullet Posted: 17 Jun 2020 at 9:18pm
It had a VGA and HDMI, that’s it.
  Quote smfcpa Quote  Post ReplyReply bullet Posted: 17 Jun 2020 at 9:20pm
I would try the VGA then, or better yet call tech support
Edited by smfcpa - 17 Jun 2020 at 9:22pm
  Quote BrennWhite Quote  Post ReplyReply bullet Posted: 17 Jun 2020 at 9:29pm
Yea unfortunately I can’t get either at 11:30pm. Can’t find a single VGA in my house.
  Quote BrennWhite Quote  Post ReplyReply bullet Posted: 17 Jun 2020 at 9:39pm
Looking at the troubleshooting guide again, I’m realizing that my keyboard is not picking up any power either(no lights, caps lock not lighting up when pressed). The next step is to clear the BIOS which I’ve already done by shorting the CLRTC pins. After that would be removing the battery from the motherboard but I can’t seem to get it out.
This page was generated in 0.1328125 seconds.
