Heat Tolerance for a standard USB Flash Drive?
Post Date: 2010-03-07
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Topic: Heat Tolerance for a standard USB Flash Drive?
    Posted: 07 Mar 2010 at 8:44pm
Um...What do you think are the heat tolerance levels for your standard USB flash drive? I had an internal USB port from a 5 port PCI USB card I bought, and I decided to just stick a USB drive in there to use for ReadyBoost.
What do you think can the little guy tolerate? It's sitting right next to my 9600 GT...
My case is the original Raven, though, so the air is able to sweep around it, instead of just blowing at it.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 09 Mar 2010 at 9:06am
should not be a problem lol
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 09 Mar 2010 at 5:13pm
Took it out, ready boost game me issues....-_-. No noticeable increase anyways.
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 09 Mar 2010 at 5:19pm
nope, no gain. lol old systems with very limited, like a 1Gb RAM on Vista, they seen a little gain, but.. lol
