Heavy computer advice for a competitive BF3 player
Post Date: 2013-03-18
babadoe View Drop Down
  Quote babadoe Quote  Post ReplyReply bullet Topic: Heavy computer advice for a competitive BF3 player
    Posted: 18 Mar 2013 at 6:43pm
[$4500]
[I want max frames if possible for any game high demanding game out.]
[Competitive FPS gaming. Bf3, etc.]
Saved Ticket #: [801470]
[I really have no idea where to start as I'm a console gamer thus far.]
Solidus1833 View Drop Down
  Quote Solidus1833 Quote  Post ReplyReply bullet Posted: 18 Mar 2013 at 8:20pm
you can do what you want for half that price.
Key components would be 8gbs of ram, 2x gtx 680s in sli, and an i5 processor. Look at the Dreadnought lvl 2. Bf3 on pc has become much easier to run over the year with better drivers from both companies. I run it with 2x amd6970s in xfire and i never dip under 60fps on ultra settings on a 1920x1200 monitor. Check this out.
Ticket 801496
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Corsair) (Model: Neutron GTX Series) (SATA 6Gbps)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 680 2GB (PhysX) (Overclocked EVGA)
This will more than max out BF3 on max settings and more for a loooong time. and for nearly Half the price at 2700bucks.
Defengar View Drop Down
  Quote Defengar Quote  Post ReplyReply bullet Posted: 18 Mar 2013 at 9:52pm
^^^ I would go with that, and put the rest of that money into getting a really nic keyboard, mouse and high res monitor(s).
Now, there is something I would change if you really insist on spending close to your limit on the tower alone. Going from 2700$ to 3700$ with the same specs, except upgrading the 680's to 690's, or Titans would get you closer, and probably keep your system relevant until Battlefield 7-8 comes out lol.
I also might suggest upping the ram to 16GB. 8 is fine for any game, but in a system of this caliber, it just seems lame to only have 8GB inside lol. Going up to an even higher level processor might be good to, although not vital. If you did, I would seriously suggest adding water cooling. Perhaps even using water cooling for your current build anyways.
  Quote Solidus1833 Quote  Post ReplyReply bullet Posted: 18 Mar 2013 at 9:55pm
16gb of ram might seem lame but 8gb of ram in 2 lanes runs better than 16gb in 4 lanes, for gaming anyway. And on the gpu's i dont know but i dont think you can turn off half of a 690 card for games that dont support sli. Which at this point MANY games dont support it. Thats why i suggested sli two cards.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 19 Mar 2013 at 4:04am
I would go with Solidus1833's build with a couple of changes.   Sli 670 will give almost the same performance for less.    Go at least Stage 1 overclocking.   Add in HDD. The WD Black is the best.   That SSD will load up real quick.   Grab the free t-shirt.
Good luck.
Edited by bprat22 - 19 Mar 2013 at 4:05am
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 19 Mar 2013 at 4:18am
Originally posted by Defengar
^^^ I would go with that, and put the rest of that money into getting a really nic keyboard, mouse and high res monitor(s).Now, there is something I would change if you really insist on spending close to your limit on the tower alone. Going from 2700$ to 3700$ with the same specs, except upgrading the 680's to 690's, or Titans would get you closer, and probably keep your system relevant until Battlefield 7-8 comes out lol. I also might suggest upping the ram to 16GB. 8 is fine for any game, but in a system of this caliber, it just seems lame to only have 8GB inside lol. Going up to an even higher level processor might be good to, although not vital. If you did, I would seriously suggest adding water cooling. Perhaps even using water cooling for your current build anyways.
For keyboard, i recommend you check out the Max Keyboard Mechanical Keyboards, they are really good and i love mine.
  Quote babadoe Quote  Post ReplyReply bullet Posted: 19 Mar 2013 at 5:34am
All this advice is really helpful so far. To make sure I'd be getting the right thing. I'll be using the newest Benq 120hz 3d monitor but on 2d. I want the system to be able to run at 120hz without dipping. I also want the system to be pretty stable and last several years as it's not everyday you have a great amount of money to use for a ocmputer. Thanks so far for all the replies.
  Quote Solidus1833 Quote  Post ReplyReply bullet Posted: 19 Mar 2013 at 12:29pm
you wont have to worry about dipping. after 60hz you wont notice anything. So running at 120 andyou dip to 60 you wont even notice.
