help choosing a monitorPost Date: 2015-05-01 |
| Author | |
funeralpyre88
Joined: 04 Feb 2011 Online Status: Offline Posts: 170 |
Topic: help choosing a monitorPosted: 01 May 2015 at 5:49pm |
I am planning on buying an Apollo with the following specs:
-Intel Core i7 5820k 3.3ghz (six-core) -ASUS X99 Deluxe -16GB DDR4 2800 MHz -1200W Corsair AX1200i -1x SSD (256GB Samsung 850 PRO) -1x NVIDIA GeForce GTX 980 4GB -H20: Stage 2: Corsair H100i GTX - 240mm Radiator Liquid CPU Cooler I am having a hard time deciding between the two monitors: Asus 24 inch VG248QE Series and Asus ROG SWIFT 27 inch PG278Q I dont know if the 1440p monitors are reliable since they are new technology. I am used to 21" 1080p monitors, that is what I used to play many games on. Im not sure if I would like the huge 27 inch size on the ROG SWIFT. and i dont know if its worth it to spend an extra $500 for a higher resolution and a few extra video techs. |
core i7-6700k @4.7 GHz
Predator 360 cpu&gpu 16 GB DDR4@2800 MHz ASUS Z-170 PRO GAMING 256 GB SAMSUNG 850 PRO 500 GB SAMSUNG 850 EVO GTX 980 TI ASUS STRIX ACER XB270HU 2560x1440 @144 hz |
ggo4th
Joined: 17 Apr 2015 Online Status: Offline Posts: 65 |
Posted: 01 May 2015 at 8:55pm |
Sounds like you have a pretty nice rig there! It'd be a shame to waste all that picture on a smaller monitor. If it were me, given the choices, I'd likely go with the 27". I personally have a 27" Samsung that I'm using right now, with another 28" ASUS on the way tomorrow. If you're on your PC a lot, it's probably worth it to go with something a little larger/better. After all, you have to look at it all day.
This may be another option, you could spend a little less ($539) and get this http://www.amazon.com/PB287Q-28-Inch-Screen-LED-Lit-Monitor/dp/B00KJGY3TO. Then, take the extra $$$ and put it towards either a second 980 or drop down to 2x 970 SLI (EVGA ACX) for the same price as the 27" monitor (a little better than $700). Not to mention, the 2x 970 SLI outperforms the single 980 on benchmarks. Food for thought. Super nice rig! Good luck! |
Apollo
Intel Core i7 4790K OC ASUS Maximus VII Hero Z97 16GB DDR3 1866MHZ Corsair Dominator 1050W Corsair HX 256GB Samsung 850 PRO / 2TB WD Black EVGA 970 ACX SLI OC Soundblaster Zx Corsair H110i GT |
funeralpyre88
Posted: 02 May 2015 at 7:27am |
I saw that 4K monitor you posted and I wonder if having 1440p at 120Hz/144Hz would be better than 4k @ 60Hz? Im not really into 4K at the moment, cause its new technology and i dont feel like buying tons of extra video cards. Also, I've read some bad reviews of the new, high-resolution monitors.
These new video cards have DSR, so I can make it look like a higher resolution even though its not. I'm currently hesitating from the ROG SWIFT atm because its so expensive, but I wonder how much the price will go down by July/August, which is when I plan to buy my new rig. |
ggo4th
Posted: 02 May 2015 at 7:43am |
It really depends I guess. With the 980, or the 970 in SLI, you could get pretty high FPS in 1440p or 1080p. Which is great! But, if you want more resolution, the dual 970s (or 980s) with the 4K would be the way, even though you're only displaying 60 FPS due to the 60hz. For me personally, I think 4K is pretty cool and was looking for a way to run it without spending $3k for a monitor and getting dual Titan X's. lol It's just in what you would prefer I suppose. If your rig is purely for gaming, a higher refresh rate may be the way. Then again, 60FPS in 4K looks pretty darn good, too. Not that you'd hit 60FPS on every game with dual 970s or even 980s (w/maxed out settings), but both cards get pretty close in most cases. This review helped me with my decision to go ahead and get the 4K monitor, as did some discussion with others. Good luck! Let us know what you decide! |
Apollo
funeralpyre88
Posted: 02 May 2015 at 7:53am |
oh, another question, you know the proper way to take care of monitors? wiping off fingerprints and dust, etc, without ruining the screen?
ggo4th
Posted: 02 May 2015 at 7:59am |
Well, I know that for most of us when we see some dirt, we tend to want to take it off with our finger (or fingernail)... and that can put scratches all over our monitors. Also, I've heard that ammonia-based cleaners are bad for screens (tv or monitor). Based on that, I'd recommend finding some wipes and/or spray (with a microfiber cloth) that don't contain ammonia. Obviously, try to keep from getting your fingers/fingernails on it as well.
Apollo
funeralpyre88
Posted: 02 May 2015 at 8:13am |
have you seen any reviews for the 1200W Corsair AX1200i power supply? I just noticed these new digital power supplies come up, and I wonder how they are better than the regular ones.
ggo4th
Posted: 02 May 2015 at 8:16am |
I haven't checked them out, yet. I'm all about a little excess, but 1200W is going too far for my rig. lol
Apollo
