help for a gaming system for WoWPost Date: 2009-12-22 |
| Author | |
millrat
Joined: 22 Dec 2009 Online Status: Offline Posts: 1 |
Topic: help for a gaming system for WoWPosted: 22 Dec 2009 at 10:00am |
My old computer has finally crashed and can't keep up with the new patches that World of Warcraft has downloaded and am looking for new system that will handle the new patches and expansion pack coming out next yr.
It's very important that the system will keep a high fps in the heat of battle. Preferably around 70 fps at the most demanding of times. If that is possible?
I'm getting a new monitor...23" with a max res. 1920x1080
Will be playing the game both with a headset and without, so speakers might be an option. Do I need a sound card?
Is there anything available that will lower latency?
Looking to spend somewhere around 2500-3000
Any help with a configuration would be appreciated. thanks
Posted: 22 Dec 2009 at 2:27pm |
anything above 60 fps will not be noticed, your eyes can't tell the difference between 60 fps and 100 fps.
Here you go Ticket# 366721 --- Price: $2125 (To see this build click here) Price after current promotion $2125 Copy of Specifications: Chassis Model: Special Deal Hot Seller - Cooler Master HAF 932 Exterior Finish: - Not Available Trim Accents: - Not Available Processor: Intel Core i7 920 2.66GHz (Quad Core) Motherboard: EVGA X58 LE Edition SLI (Intel X58 Chipset) (Supports SLI or CrossFire) System Memory: 6GB DDR3 1600MHz Digital Storm Certified (Highly Recommended) (Hand Tested) Power Supply: 750W Corsair TX (Dual SLI Compatible) Expansion Bay: - Not Available Hard Drive Set 1: Operating System: 1x (500GB Western Digital (16MB Cache) (7200 RPM) (SATA) Set 1 Raid Options: - Not Available Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 22x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x ATI Radeon HD 5870 1GB Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 1: Noctua Dual 120mm Fans High Performance Cooler (Compatible With ONLY i7 Processors) H20 Tube Color:- Not Available Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Red) Enhancements: - Not Available Chassis Mods: - Not Available Noise Reduction: - Not Available Boost Processor: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Requires Air Cooling Upgrade) Boost Video Card: - Not Available Boost Memory: - Not Available Boost OS: - Not Available Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) Virus Protection: - Not Available Office: - Not Available Benchmarking: - Not Available Install/Test Game: FREE: Please include a free copy of a hot-selling game Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Large) Priority Build: - No Thanks, Ship Within 5-10 Business Days After Order Is Successfully Processed Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty not a sound person so can't help you there but if you like quality sound then pick a sound card. Edited by DST4ME - 22 Dec 2009 at 2:27pm |
Invader Mig
Joined: 05 Aug 2009 Online Status: Offline Posts: 244 |
Posted: 23 Dec 2009 at 11:16am |
DST while your right that he won't notice anything above 60fps, it's not because the human eye can't recognize framerates higher than 60fps, its because 99.9% of monitors have a 60hz refresh rate.
I know this is my first time posting and I'm not trying to bust your chops, but I just felt the need to chime in. I've seen so many people on this forum as well as others say that your eyes can't see more than 60fps. Not sure where people came up with that. On a 2233rz you can see the difference between 60 and 100+ frames. |
Posted: 23 Dec 2009 at 6:28pm |
I will disagree, we have had people here with 120Hz monitors and they will tell you the same thing. Yes some things are better image quality but not everything, and I have not seen one person that say they can tell the difference between gaming at 60fps and 80fps no matter if its 60hz or 120hz monitor.
also with a 120hz if I'm not mistaken, 30fps looks better then 30fps at 60hz, so with 120hz you need even less fps to have a smooth gaming experience. not only can you not tell the difference but at 60fps you are having a smooth gaming experience, so even if your eyes could tell the difference, you won't notice the difference, cause once everything is smooth with no lag then there is no difference you could tell. no matter what the res, 1200 x 1000 / 1600 x 1200 / 1900 x 1200 / or 2560 x 1600, if you are getting 60fps in a game, that means you are getting a smooth gaming experience, after that point you can't tell the difference. |
Invader Mig
Posted: 24 Dec 2009 at 6:12am |
I'm not trying to say that it's game breaking or that 60fps isn't a great framerate to play at. I was just trying to point out that the human eye is most definitely capable of noticing the improvement of frame rates above 60fps.
By the way people explain themselves I've always gotten the idea that the message was the human eye is incapable of processing the information, so anything above that framerate would literally be impossible to see. Unless someone you know had either a 2233rz or a Viewsonic VX2265wm, with SLI/Xfire to get over 100 fps then disabled it, in order to bring the frame rate down to around 60ish in a particular game, I don't really see how they or you could know. In any case it doesn't really matter. As far as your advice for smooth gaming at 60fps, I agree. My point was just that it is noticeable. |
Clinton
Joined: 08 Sep 2007 Online Status: Offline Posts: 298 |
Posted: 24 Dec 2009 at 7:25am |
I've played games that have felt too smooth before. It was probably my imagination, but it was pretty weird and it didn't feel real. Didn't like it at all.
Captain Francis
Joined: 13 Dec 2009 Online Status: Offline Posts: 117 |
Posted: 24 Dec 2009 at 10:53am |
I heard too many FPS can give you a headache, but I'm not sure on that one.
I guess if the monitor is only 60hz, that won't happen. *shrug* |
