Help for config for my games
Post Date: 2013-12-02
Moonz View Drop Down
  Quote Moonz Quote  Post ReplyReply bullet Topic: Help for config for my games
    Posted: 02 Dec 2013 at 4:15pm
I want to know if I will be able to play my games at high frame rate with high settings.
Here is the post template filled:
1500$ with taxes and standard shipping to Canada included (Postal Code: J3G 0G8).
Play my games at a good fps speed (60) at high settings.
Play those games:
APB: Reloaded
Infestation: Survivor Stories
War Thunder
ARMA II
Smite
Saved Ticket #: 900506 (Vanquish Level 3)
Chassis Model: Special Deal Hot Seller - Pre-built Digital Storm Vanquish - Level 3
Processor: Intel Core i5 4570 3.20 GHz (Quad Core)
Motherboard: ASUS Z87-C (Intel Z87 Chipset)
System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series
Power Supply: 600W Corsair CX
Storage Set 1: 1x (1TB Seagate (7200 RPM) (64MB Cache)
Storage Set 2: - No Thanks
Graphics Card(s): 1x NVIDIA GeForce GTX 760 2GB (Includes PhysX)
Extreme Cooling: AIR: Stage 1: Cooler Master Hyper 212 EVO (High Performance Cooler)
Airflow Control: - No Thanks
CPU Boost: - No Thanks, Please do not overclock my processor
Portable Gaming: - No Thanks
Priority Build: Ship Within 72-Hours After Order Is Successfully Processed (3 Business Days)
Edited by Moonz - 02 Dec 2013 at 4:16pm
danjw1 View Drop Down
  Quote danjw1 Quote  Post ReplyReply bullet Posted: 02 Dec 2013 at 6:45pm
We can't really answer that without knowing the resolution of the monitor you are going to play on.
A quick Google search of "APB: Reloaded minimum requirements" led me to this page: http://www.game-debate.com/games/index.php?g_id=1434&game=APB:%20Reloaded&p_make=Intel&gc_make=Nvidia&p_deriv=Core+i5-4570+3.2GHz&gc_deriv=GeForce+GTX+760&laptop=0#systemRequirements
I suggest you try the same search for the other games.
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 03 Dec 2013 at 8:26am
If you're using a 1080P monitor, you'll probably get medium to high settings on most games and possibly higher with games that don't demand too much visually. You might need to lower certain settings to boost others.
  Quote Moonz Quote  Post ReplyReply bullet Posted: 03 Dec 2013 at 1:47pm
Okay thx :)
