help...i need some suggestions on upgrading my pc
Post Date: 2013-03-05
jinomas View Drop Down
  Quote jinomas Quote  Post ReplyReply bullet Topic: help...i need some suggestions on upgrading my pc
    Posted: 05 Mar 2013 at 9:08pm
my system is 3 yrs old and looking for some upgrades.
My current config is:
Chasis: HAF922
Processor: Intel Core i7 930 2.8 GHz (Quad Core)
Motherboard: EVGA X58 LE Edition SLI (Intel X58 Chipset)
System Memory: 6GB DDR3 1600Mhz DStorm certified series
Hard Drive: 1x (500GB Western Digital (16MB)(7200)(SATA)
Video Card: 1x ATI Radeon HD 5750 1GB
Extreme Cooling: Stage 1 Noctua Dual 120mm
Windows OS: Window 7 Home
I mainly play first person shooter,starcraft, and just everyday use. Any suggestions starting with highest priority that you see that is a MUST GO will be appreciated.
jp
Solidus1833 View Drop Down
  Quote Solidus1833 Quote  Post ReplyReply bullet Posted: 05 Mar 2013 at 10:02pm
from ur setup it looks like you are running exactly what i was before i started upgrading
i had ur exact set up but was running 2x 5770s
so i threw in 2x 6970s and i can game everything on max settings except for crysis 3. That one takes a lil finesse to run, i currently can only get it to around 45-50fps, which isnt terrible i know, but i dont like playing anything unless i get atleast a stable 55-60fps.
i did bump my ram to 12gb but i see no difference, i thnk the 930cpu just doesnt cut it tbh. This is why im looking into the Hailstorm.
in order for me to upgrade any more and actually utilize any money i throw at it, i need a new cpu, and mobo. the lga 1366 is icky,,, u cant even find mobos for them any more. my prob is i have an Alienware system, which is nearly incompatible with anything not dell.So i have to build from scratch,
you on the other hand, i would start with 2 parts, an ivy bridge i5, and a new mobo z77. This is because im sure all of your other parts will be compatible with these two switches.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Mar 2013 at 12:06am
I disagree, nothing wrong with 1366, you just need to get a good warranty from the builder, I got a 5 year part warranty from DS, so whether you can find a 1366 mobo or not is not an issue for me, thats DS's problem.
IMHO what you need jinomas is a gpu upgrade and ssd, you upgrade a mobo when it dies.
what res you playing at?
Edited by DST4ME - 06 Mar 2013 at 12:06am
  Quote jinomas Quote  Post ReplyReply bullet Posted: 06 Mar 2013 at 12:34am
Thx, both of you. So, upgrade the video card and more ram? what is SSD? ram or hard drive? sorry, i'm a complete noob. DST4ME, what do u recommend for a gpu and ssd?
jp
  Quote jinomas Quote  Post ReplyReply bullet Posted: 06 Mar 2013 at 12:36am
oh my current display 1680 x 1050
jp
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Mar 2013 at 12:44am
LOL in that case jimomas I first suggest you upgrade to a good 24" ($300 to $600) and if you want a good monitor you want an ips panel so checkout the dell ultrasharps, lot of people here have them, I have a few:
Dell UltraSharp Monitors
then you need a 670 gtx and a ssd which replaces your hard drive, its much faster, no moving parts.
you don't need more ram, unless you find the ram you have is not enough now.
Edited by DST4ME - 06 Mar 2013 at 12:45am
  Quote jinomas Quote  Post ReplyReply bullet Posted: 06 Mar 2013 at 12:54am
ok so a new monitor, 670 gtx, and can you give me a link to a ssd? lol, honestly i'm confused what this ssd and ssd replacing the hdrive is about
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Mar 2013 at 1:05am
hdd = hard disk drive (this drive stores data on a a disk that spins) this is what you have.
ssd = solid state drive (this drive stores data on a flash memory, has no moving parts, has much faster speeds than a hdd)
have a look here
and here
Edited by DST4ME - 06 Mar 2013 at 1:06am
  Quote Solidus1833 Quote  Post ReplyReply bullet Posted: 06 Mar 2013 at 1:20am
have a look here
and here
computer ninja!
  Quote Solidus1833 Quote  Post ReplyReply bullet Posted: 06 Mar 2013 at 1:22am
I have to agree with dst on the monitors. Dell isnt very good at much but one thing they do Great is there monitors i myself have one of their 27"s but i wouldnt recommend it because of the price 700 was a little steep.
