Help! Looking for a good 24inch monitor
Post Date: 2009-06-04
Ramdurand View Drop Down
  Quote Ramdurand Quote  Post ReplyReply bullet Topic: Help! Looking for a good 24inch monitor
    Posted: 04 Jun 2009 at 2:59pm
I am really close to getting my computer from DS and i need to find a monitor.  I want a 24inch 1900x1200.  I don't want a cheap one but i don't want to spend 1000 bucks either.  I want one that can handle some heavy gaming.  Any help would be awesome Ermm
Sarah View Drop Down
Hardcore Gamer
  Quote Sarah Quote  Post ReplyReply bullet Posted: 04 Jun 2009 at 3:10pm
Check out Samsung, I am a big fan of their products and from what I have seen their monitors are extremely nice as well.
Sarah
Bahger View Drop Down
  Quote Bahger Quote  Post ReplyReply bullet Posted: 04 Jun 2009 at 3:16pm
I have a very sincere recommendation for you, which is the Benq 24-incher here.  There are surprisingly few high-performance 24" monitors suitable for gaming and after a lot of research I bought this one.  It is superb, and relatively reasonably priced for what it is.  The only weakness is that the mounting is a little delicate, one reason why I have virtually banned my children from my office.
Edit: The Benq runs at 1920 x 1200, btw, assume that won't be a problem!
Edited by Bahger - 04 Jun 2009 at 3:19pm
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 04 Jun 2009 at 3:22pm
Thanks Sarah and Bahger.  I looked at that one Bahger.  Like all the monitors i found they have some good reviews and some bad ones.  I don't care if it tilts or swivels or anything like that i will be looking at it straight on.  Its a tuff decision.  Where did you get yours?
  Quote Bahger Quote  Post ReplyReply bullet Posted: 04 Jun 2009 at 3:36pm
I got mine at NewEgg.  FWIW, I have never found the lack of height adjustment to be an issue and you can tilt it of course.  I do not recall any review of this monitor finding fault with anything but the above issues.  It seems that Samsung, HP and even Dell have very well-regarded high-performance 24" LCDs with 1920 x 1200 res but for me this was a clear winner, partly because it seems to be about $100 - $200 cheaper.  There were no dead pixels, the color is brilliant and it can keep up with what the mighty DS rig is pushing at it.
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 04 Jun 2009 at 3:40pm
Cool thanks Bahger that helps alot.  I was leaning towards a Samsung but there mixed reviews also.  I always worry about ordering a monitor online.  I have heard so many stories of DOA or DP or something else wrong.
  Quote Bahger Quote  Post ReplyReply bullet Posted: 04 Jun 2009 at 3:53pm
Well, read the small print carefully.  Funnily enough I had to return a monitor to NewEgg because I clicked twice and ordered two by mistake!  The returns process went very smoothly, all I had to do was print out a label, fix it to the box and drop the thing off at the local UPS store.  Keep all the packaging for a couple of weeks.  And double check the NewEgg returns policy; I think they will accept returns with a certain (small) number of dead pixels as well as all the usual reasons.
I hesitated to order a monitor online, too, but there was no choice.  Stores simply don't stock the high-end LCDs, they are a niche item and not worth the outlay for the stores or the shelf-space.  I suspect you'll be finding yourself buying online.  NewEgg is very good.
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 04 Jun 2009 at 4:06pm
I heard NewEgg is hard to return stuff.  I have never ordered anything from them.  It sucks that there isn't a store you could go to other than Office Max or Best Buy to look at monitors.  I don't know where you live but here in Wisconsin there isn't much to chose from.
e.fruman View Drop Down
  Quote e.fruman Quote  Post ReplyReply bullet Posted: 04 Jun 2009 at 8:47pm
best monitor for a under 300 budget is this samsung
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001330
Mikey14 View Drop Down
  Quote Mikey14 Quote  Post ReplyReply bullet Posted: 04 Jun 2009 at 9:00pm
I'm considering the LG W2453V-PF 24" monitor.  Does anyone have any reviews or opinions on it?  Any help is appreciated.
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 05 Jun 2009 at 9:50am
Hey E. I can't open the page check the link.  Thanks.  Mikey have you checked out the Benq that Bahger got?
NullForce View Drop Down
  Quote NullForce Quote  Post ReplyReply bullet Posted: 05 Jun 2009 at 10:21am
hihi
  Quote e.fruman Quote  Post ReplyReply bullet Posted: 05 Jun 2009 at 10:57am
I actually mean this one, those are all above 300.Samsung 23"
Edited by e.fruman - 05 Jun 2009 at 11:05am
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 05 Jun 2009 at 10:59am
I don't know why E but everytime i click the link i go to a DS site not newegg.
"Sorry, but the page you are looking for is missing. It may have moved to a new page. Please view the site map below to find what you are looking for."
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 05 Jun 2009 at 11:02am
Thanks for the link NullForce.  Do you guys think that its better to have HDMI or DVI as the hook up to your computer.
  Quote e.fruman Quote  Post ReplyReply bullet Posted: 05 Jun 2009 at 11:05am
check it now i got it work lol i hate safari and bbcode just dont mix well.
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 05 Jun 2009 at 11:09am
Got it E.  You like that one?
  Quote e.fruman Quote  Post ReplyReply bullet Posted: 05 Jun 2009 at 12:33pm
NVM buy.com has a amazing deal thats only going to last today so if i were you hit that check out button now before its gone.
http://www.buy.com/prod/viewsonic-vx2433wm-24-23-6-viewable-widescreen-1080p-lcd-monitor-20/q/loc/101/210558274.html?adid=17992&dcaid=17992
paraguy1 View Drop Down
  Quote paraguy1 Quote  Post ReplyReply bullet Posted: 05 Jun 2009 at 4:51pm
The best 24" is the samsung 245T well at least it was a few months back not sure if anything has come out that matches or beats its specs but it is alsio a pricey moniter. Its the one I own but I regret not getting the 30" samsung 305T instead.
  Quote NullForce Quote  Post ReplyReply bullet Posted: 05 Jun 2009 at 7:31pm
My bad, i forgot 299.99 is above 300 :P
Ermm
HDMI
hihi
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 05 Jun 2009 at 10:55pm
Hey Paraguy how is that monitor for gaming?  Any issues?
Null why do you think HDMI is better?  I asked Sarah if i could connect an HDMI monitor to the HAF case and this is what she said.  "Totally, you just need a DVI to HDMI converter for your video cards."  Whats that mean?
  Quote NullForce Quote  Post ReplyReply bullet Posted: 05 Jun 2009 at 11:05pm
HD!
You'd need something like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16882021060
Allows you to connect an HDMI cable to video cards that lack an HDMI port
hihi
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 07 Jun 2009 at 5:09pm
What are the bennies of using HDMI over DVI?  I am never going to watch TV on my monitor so do i need HDMI?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Jun 2009 at 5:23pm
hdmi carries sound dvi does not, other then that they are pretty much the same.
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 07 Jun 2009 at 5:26pm
So all it does is to have sound come through the monitor?  Nothing with the picture quality?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Jun 2009 at 5:37pm
picture quality will be the same. difference is sound.
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 07 Jun 2009 at 5:40pm
Do many people listen to there sound through the monitor?  I would like to have some speakers because i don't think the sound can be to good coming from the monitor.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Jun 2009 at 5:43pm
Well most monitors don't have sound, you need to add speakers, the hdmi is more for TV kind of monitors I guess.
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 07 Jun 2009 at 5:48pm
I guess if it comes with it comes with.  I think i will stick to the DVI.  Thanks DST!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Jun 2009 at 5:57pm
My pleasure boss
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 10 Jun 2009 at 5:06pm
I really need help finding a good gaming monitor.  My computer is coming next week and i need to find one fast.  I was looking at the Dell ultrasharp 2408fp but i heard its got input lag.  I just want one that isn't going to be lagging and isn't going to last 1 year.  Its really tough to find one.
  Quote Bahger Quote  Post ReplyReply bullet Posted: 10 Jun 2009 at 5:25pm
You've already gotten plenty of advice; now it's up to you.  As I said before, I just went through the same thing and, after much research, bought the Benq.  It's a fantastic monitor.  You'll need to overcome your resistance to buying online, I'm afraid, retail sores just don't carry high-end monitors, t's not worth their while.
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 10 Jun 2009 at 5:54pm
I know Bahger its just i can't seem to find one thats "the one to get" you know what i mean.  I need to get one soon too.  I looked at the Benq and its hit or miss.  Same with Samsung.  I have looked at so many reviews and i haven't found one thats the best.  HELP LOL!!!
  Quote e.fruman Quote  Post ReplyReply bullet Posted: 10 Jun 2009 at 6:21pm
Have you looked at acer this one's got great reviews.
ASUS VW246H type it in at newegg im bad with links.
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 11 Jun 2009 at 10:37am
What do you guys think of this monitor?  It got pretty good reviews.  It doesn't seem to have to bad of a lag problem.  I am sure its got a little but noticeable, i don't know?  SAMSUNG 2443BWT
