Help my build
Post Date: 2020-04-29
Peter1195 View Drop Down
  Quote Peter1195 Quote  Post ReplyReply bullet Topic: Help my build
    Posted: 29 Apr 2020 at 3:05pm
2300 US dollars
Expectations: Id like help on choosing everything else apart from what i mentioned ,if people could build around that and offer like what motherboard would be best etc that would help alot. I am quite clueless
Gaming I want to use this rig for gaming , specifically espcape from tarkov and the likes of post scriptum. Im happy to play in 1080p.
at least an I7 processor , 500 gig ssd , 32 gig ram and 2060 super. I hear the 2060 super is good and i can upgrade later on.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 30 Apr 2020 at 4:00am
Here you go, $2100 with the discount. Free shipping. You don't need 32 GB of RAM for gaming any time in the forseeable future, but it's in there. With the room in the budget, you could make a small change or two, but this rig is not gimped anywhere strictly for price. It will run great as-is for a very long time.
(Edited to show the highlights)
To see this build in the Configurator, copy the ID# ONLY and paste it into the window that opens when you click "Load Config" in the upper right of the DS main page.
Digital Storm Desktop - Config ID 3043134
$2,300.00     $2,300.00
Chassis Model: Digital Storm Lynx
Processor: Intel Core i7-9700K (4.9 GHz Turbo) (8-Core) 3.6 GHz
Motherboard: ASUS ROG Strix Z390-H Gaming (Intel Z390 Chipset) (Up to 3x PCI-E Devices)
Power Supply: 850W Corsair / EVGA / Thermaltake (Modular) (80 Plus Gold)
Storage Set 1: 1x SSD M.2 (500GB Seagate FireCuda 520) (NVM Express) (Gen4 PCIe)
Graphics Card(s): 1x GeForce RTX 2060 SUPER 8GB (VR Ready)
Chassis Fans: Digital Storm Performance Series (RGB Fans)
Priority Build: - No Thanks, 6 Week Ship Estimate After Order Is Successfully Processed
Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor and 1 year Part Replacement)
--PROMTIONAL LIMITED TIME BONUS DISCOUNT:$200
If you wanted to get a LUMOS instead, it would be $116 more for just the case.
The 9700K CPU is equally fast as the 9900K and a better choice for gaming.
Questions?
  Quote Peter1195 Quote  Post ReplyReply bullet Posted: 30 Apr 2020 at 4:03am
Wow thanks alot
I thought i nees more ram for gaming , so playing multiple games will only require 16gigs ram ? I appreciate the time ye took to write out the config.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 01 May 2020 at 3:47am
16GB is plenty. If you ever found a need for more during the life of this rig, it's just about the easiest upgrade to make. Buy it, plug it into the slots.
If you saved money there, you could easily step up to a Lumos case and maybe even get the Corsair LL Series case fans to really show it off. with everything else the same in the previous build, those two changes would get it up to $2197 after discount. Still inside your budget.
smfcpa View Drop Down
  Quote smfcpa Quote  Post ReplyReply bullet Posted: 01 May 2020 at 12:19pm
Originally posted by Peter1195
Wow thanks alot
This motherboard will support up to 64gb of memory. The benefit of having more memory than required is non existent. I don't think anyone could tell you the effect of running multiple games simultaneously.You would need to experiment.
Ariktu View Drop Down
  Quote Ariktu Quote  Post ReplyReply bullet Posted: 01 May 2020 at 11:42pm
I agree with people saying to step down to 16 GB of ram. If you did that you could also bump up the GPU to a RTX 2070 super or just save the money and upgrade to a newer GPU down the line.
As always Cretae's build is great.
Good luck.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 02 May 2020 at 3:23am
Pleasure to help. Please let us know how what you decide
Thank you, Ariktu.
