help narrowing a few things down please
Post Date: 2013-04-01
finz View Drop Down
  Quote finz Quote  Post ReplyReply bullet Topic: help narrowing a few things down please
    Posted: 01 Apr 2013 at 8:59am
3500
Nvidia 2d and 3d surround
Gaming
[Please Type Here]
Saved Ticket : 807814
I'm on the fence with a few things and could use some advice.
1. I can't decide on what would be the best gpu setup. I will be running 3 vg248qe monitors in surround and eventually 3d surround. I can budget all the way to a gtx titan. I've read the pros and cons about sli, but the bottom line is that I have the proper gpu(s) to run everything smoothly.
2. I've the noctua cooler loaded into configuration but still can't decide on that or h100i.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 01 Apr 2013 at 9:35am
Unless your games are not friendly to sli, then a sli gtx 670 will out perform the Titan for alot less money.
I would stick with the Noctua d14.  Quiet, dependable and cools great.
Nice build you put together. Strong
Good luck. Big%20Smile
Solidus1833 View Drop Down
  Quote Solidus1833 Quote  Post ReplyReply bullet Posted: 01 Apr 2013 at 11:35am
just remember what ever the ratings on different GPU'd and their frame rates, HALF that and that is its 3d frame rate roughly. If i were you i would do what bprat suggests, SLI 2 670s or 680s if you cant afford 2 titans.
