::HELP:: No FAN RGBS ARE LIT
Post Date: 2021-04-11
VIIJO View Drop Down
  Quote VIIJO Quote  Post ReplyReply bullet Topic: ::HELP:: No FAN RGBS ARE LIT
    Posted: 11 Apr 2021 at 12:56am
CryHEY GUYS! i need help with my Fan RGBS plz - so i recieved my Aventum X the other day April 9th. Been trying to get my Cooler Master MasterFan Halo (RGB Fans) (Remote Control Only) (14 Fans Total) to light up with the remote control but doesn't seem to do anything when i click on the buttons. but the Fan's are Spinning and showing up in the icue Software.
(Not as important - Neither are my Light strips inside the case working.)
The only software that was installed was ICue due to having Commander Pro's for fan Controllers.  ICue Software: all that seems to appear in the ICue software are my RAM sticks, Three Corsair Commander Pro's and My Asus Mobo.
Here's my Build Configuration.
Chassis Model: Aventum X
Processor: AMD Ryzen 9 5950X (16-Core) 4.9 GHz Turbo
Motherboard: ASUS ROG Crosshair VIII Formula (Wi-Fi) (AMD X570 Chipset) (Up to 3x PCI-E Devices)
System Memory: CORSAIR Vengeance RGB Pro 128GB (4 x 32GB) 288-Pin DDR4 SDRAM DDR4 3600 (PC4 28800)
Power Supply: 1200W Silverstone / EVGA / Thermaltake (Modular) (80 Plus Gold)
Storage Set 1: 1x SSD M.2 (1TB Samsung 980 PRO) (NVM Express)
Storage Set 2: 1x SSD M.2 (1TB Samsung 980 PRO) (NVM Express)
Storage Set 3: 1x SSD M.2 (2TB Seagate FireCuda 520) (NVM Express) (Gen4 PCIe)
Graphics Card(s): 1x Radeon RX 6900 XT 16GB (VR Ready)
Extreme Cooling: H20: HydroLux PRO: Exotic Custom Cooling System (CPU Only)
HydroLux Fluid Color: Red Fluid + Clear Tubing (Requires HydroLux Liquid Cooling System)
Chassis Fans: Cooler Master MasterFan Halo (RGB Fans) (Remote Control Only) (14 Fans Total)
Internal Lighting: Remote Controlled Advanced LED Lighting System
Airflow Control: Corsair Commander PRO Management Control Board & Software (3x Boards)
Edited by VIIJO - 11 Apr 2021 at 3:47am
Config ID 3801255 Stage 1: 12/14/20 | Stage 2: 2/14/21 | Stage 3: 2/15/21 | Stage 4: 3/16/2021 | Stage 5: 3/17/2021 | Stage 6: 3/19/2021 | Stage 7: 3/24/2021 | Shipped: 3/24/2021 | Arrived: 4/9/2021
  Quote hoserator Quote  Post ReplyReply bullet Posted: 11 Apr 2021 at 3:36am
Sorry about the issue. Check all the connections manually (visually not enough in my experience) in the rear and into the mobo (If you can). Shipping is rough!!
Hopefully someone with that system can chyme in  regarding the remote and iCUE settings.
And if all seems as it should be, contact DS for assistance.
Good luck.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 11 Apr 2021 at 6:14am
Yeh, it seems a couple of wires have come undone. DS takes a pic of everything working before they send it out. It's normal that the Corsair iCue software doesn't see Coolermaster fans.
If no results, you'll have to see DS support.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 12 Apr 2021 at 2:30am
Make sure the Commander Pro is set to some non Corsair fan setting in Lighting. Or try the different ones to see if one works.
Keep us posted and good luck.
Nice image!! Drooling
Are the HDD cages set like that?
misy View Drop Down
  Quote misy Quote  Post ReplyReply bullet Posted: 08 Dec 2021 at 10:48pm
Originally posted by VIIJO
CryHEY GUYS! i need help with my Fan RGBS plz - so i recieved my Aventum X the other day April 9th. Been trying to get my <span style="font-size:11pt;">Cooler Master MasterFan Halo (RGB Fans) (Remote Control Only) (14 Fans Total) to light up with the remote control but doesn't seem to do anything when i click on the buttons. but the Fan's are Spinning and showing up in the icue Software.
did you get your RGB fan lights working? I just got mine in and same problem RGB fan lights nor light strips are working, now the controller
.. cleaned up quote ..
Edited by Snaike - 09 Dec 2021 at 9:12am
  Quote VIIJO Quote  Post ReplyReply bullet Posted: 09 Dec 2021 at 8:57am
The led hub on the back was faulty. Digitastorm sent me a new one to hook up to replace the one i had and now they all work accordingly. Contant then to get a replacement led hub.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 10 Dec 2021 at 3:22am
  Quote hoserator Quote  Post ReplyReply bullet Posted: 11 Dec 2021 at 9:16pm
Great news that you got it resolved.
Smile
