help - no power
Post Date: 2009-06-08
kleo View Drop Down
  Quote kleo Quote  Post ReplyReply bullet Topic: help - no power
    Posted: 08 Jun 2009 at 8:17am
My system has no power today - worked fine yesterday. No lights on motherboard either. This is a new DG system - 3 mos old.
Power supply, yes?? Anything else I can try?
How do you test power supply?
Bill the Cat View Drop Down
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 08 Jun 2009 at 8:54am
I assume that you've tried plugging other things into the outlet where your computer is plugged in. Is there a switch on the back of the PSU? Does the PSU have a fan that's running/not running?  The only way I know to test a PSU is with a volt/ohm meter.
Maybe it's the PSU, but maybe it a motherboard failure.
kleo View Drop Down
  Quote kleo Quote  Post ReplyReply bullet Posted: 08 Jun 2009 at 9:48am
I've tested the outlet and tried another power cord. The PSU fan is not running and there are no lights on the motherboard.
Zurginator View Drop Down
  Quote Zurginator Quote  Post ReplyReply bullet Posted: 08 Jun 2009 at 10:14am
Flip the switch on the back of the Power Supply and try again.
If that doesn't work, you should jump start the PSU to see if it's that or the motherboard.
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 08 Jun 2009 at 11:50am
I hate to suggest it, but this is the kind of issue that you could take to Best Buy or even Staples or your local "screw driver" shop just for a thumbs up/thumbs down diagnosis on the PSU, if you're not inclined to do it your self. If the PSU is dead, replace it. If it's something worse, take a deep breath (not necessarily of just air) a stiff drink and comtemplate your options....
Oh yeah, one last thing.... Does the PSU have a fuse by any chance?
Edited by Bill the Cat - 08 Jun 2009 at 11:52am
inferno23 View Drop Down
  Quote inferno23 Quote  Post ReplyReply bullet Posted: 08 Jun 2009 at 2:04pm
I had an similar experience with my wii. it was on 1 day the next day it was off and wouldnt come back on after switching sockets and everything else. I have to tell you i was pissed. I unhooked for a day and pluged it in the next day with a prayer and to my hopes it came back on YAY i did a backflip. I dunno what was going on but i guess it was overheated or something. try keeping unplugged for a day or 2 and see if it wont work again
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 08 Jun 2009 at 8:50pm
FYI:
Modern ATX power supplies turn on when pin 14 on the ATX connector (the only green wire) is connected to ground (any black wire). A paper clip is adequate to do this:
PSU%20plus%20paper%20clip
If the PSU is alive, the next step is to start removing components from the system. Granted, there aren't that many, but  you can pull the RAM and the GPU(s) at least, maybe the disk drives....  After removing each item, see if what's left powers up.
Edited by Bill the Cat - 09 Jun 2009 at 11:04am
This page was generated in 0.1142578 seconds.
