Help on PC buildPost Date: 2010-07-30 |
LTrimble
Newbie Joined: 30 Jul 2010 Online Status: Offline Posts: 2 |
Topic: Help on PC build Posted: 30 Jul 2010 at 11:42pm |
Hello I just got back from basic training and am putting my signing bonus to good use in buying a new gaming machine. I'm willing to put about $1300 into it and help help on builds would be so appreciated. I am big into fps games such as BFBC2 and CoD MW2. But I also am looking to get FF XIV when it launches as well as Star Craft 2. So a build that would just be able to run those smoothly and with high settings is really what im looking for out of my DS PC.
teaiewold
Groupie Joined: 26 Jun 2010 Online Status: Offline Posts: 216 |
Quote Reply Posted: 30 Jul 2010 at 11:54pm |
if you really want to put your enlistment bonus to good use you should invest it.
dustymanhp
Newbie Joined: 27 Jun 2010 Online Status: Offline Posts: 46 |
Quote Reply Posted: 31 Jul 2010 at 12:03am |
Yea! invest it!!!!
IN A NEW COMPUTER!!!!
Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i5 750 2.66GHz (Quad Core) Motherboard: EVGA P55M SLI (Intel P55 Chipset) System Memory: 4GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W Digital Storm Certified (Dual SLI Compatible) (Silent Edition Recommended) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (500GB Western Digital (16MB Cache) (7200 RPM) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x NVIDIA GeForce GTX 460 1GB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 1: High Performance Cooler (Compatible With ONLY i5/AMD Processors) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: - No Thanks Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks Boost Processor: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Cooling Upgrade Recommended) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) should run things smoothly
LTrimble
Quote Reply Posted: 31 Jul 2010 at 12:24am |
Thank you for the build dusty, much appreciated. And teaiewold the total was 20k. The rest will be in the bank :P
Ch3ssplay3r
Groupie Joined: 23 Jul 2010 Online Status: Offline Posts: 164 |
Quote Reply Posted: 31 Jul 2010 at 9:00pm |
lol. very nice dusty, but here's a rough comparision of investments by annual yield.
Standard CD interest rate: 4ish% Stock market interest rate(if you're good)10ish% Real-estate(prereccession) 5ish% New computer... -50% yeah, just pulled those off my head randomly. not 100% accurate ANYWAY!... dusty's build is good. lol. I would actually upgrade to the noctua dual 120mm fans for cooling. far better than that cooler. Edited by Ch3ssplay3r - 31 Jul 2010 at 11:54pm |
