Help on selecting computer
Post Date: 2016-03-08
Buzz_Cut View Drop Down
  Quote Buzz_Cut Quote  Post ReplyReply bullet Topic: Help on selecting computer
    Posted: 08 Mar 2016 at 3:59pm
I've never built a gaming rig before, and I'm planning to either get the Apollo, Bolt 3 or Bolt 3 Pro. It has to be a budget of under $2,500. I have already chosen the parts for all of the desktops, but I'm not sure which one would be worth the money. If anyone can help me choose what parts exactly I would need, please feel free do do so. What I'm planning to use the Desktop for is Video Editing (Adobe Premiere Pro) Animating (Adobe After Effects) and Photoshop. BTW I'm planning to buy it about a year from now if its not outdated =). Let me know what you guys think! All my builds will be down below, or you can use the configuration code.
Bolt 3
Configuration Code: 1383279
Total Price with Instant Savings: $2,222.00
Chassis Model: Special Deal Hot Seller - Pre-built Digital Storm Bolt 3
Exterior Finish: Black Brushed Aluminum Hairline Finish
Trim Accents: Edge to Edge Premium Acrylic
Processor: Intel Core i7 6700K 4.0GHz (Codename Skylake) (Unlocked CPU) (Quad Core)
Motherboard: GIGABYTE Z170N-Gaming 5 (Intel Z170 Chipset) (Mini-ITX) (Up to 1x PCI-E Device)
System Memory: 16GB DDR4 2666MHz Digital Storm Certified Performance Series <br><strong></strong>
Power Supply: 450W SilverStone ST45SF (Bronze Rated) (Supports up to GTX 980)
Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 8x / CD-Writer 8x)
Storage Set 2: 1x Storage (1TB Seagate / Western Digital / Toshiba)
Graphics Card(s): 1x NVIDIA GeForce GTX 970 4GB (VR Ready)
Extreme Cooling: BACKORDERED: Digital Storm HydroLux PRO (CPU Only) (ETA: Early March 2016) <br><strong></strong>
HydroLux Tubing Style: Flexible Tubing (Requires HydroLux Liquid Cooling System) <br><strong></strong>
HydroLux Fluid Color: Red Fluid (Requires HydroLux Liquid Cooling System) <br><strong></strong>
Chassis Fans: Standard Black 120mm Fans
Internal Lighting: - No Thanks, Front Panel LED Lighting Only
Airflow Control: - No Thanks
Branded Gear: - No Thanks
Apollo
Configuration Code: 1383287
Total Price with Instant Savings: $2,295.00
Chassis Model: Special Deal Hot Seller - Digital Storm Coridium <br><strong></strong>
Motherboard: GIGABYTE Z170MX-Gaming 5 (Intel Z170 Chipset) (MATX) (Up to 3x PCI-E Devices)
Power Supply: 750W EVGA SuperNOVA (750 B1)
Extreme Cooling: H20: HydroLux LITE: Integrated Cooling System (CPU Only) <br><strong></strong>
Chassis Fans: Corsair Airflow Performance Edition (Up to 6 Fans) <br><strong></strong>
Airflow Control: Digital Storm Thermal Management Control Board & Software <br><strong></strong>
Bolt 3 Pro
Configuration Code: 1383289
Total Price with Instant Savings: $2,196.00
Side Window: Edge to Edge Premium Acrylic
Motherboard: ASUS Z170I PRO GAMING (Intel Z170 Chipset) (Mini-ITX) (Up to 1x PCI-E Device)
Storage Set 2: 1x Storage (2TB Western Digital / Seagate / Hitachi)
Graphics Card(s): 1x NVIDIA Quadro K620 2GB (Outputs: 1 x DVI-D ; 1 x DisplayPort 1.2)
Chassis Fans: High Static Pressure - Corsair Air Series SP120 Fans (2x 120mm) <br><strong></strong>
Edited by Buzz_Cut - 08 Mar 2016 at 4:10pm
