Help overclocking x6800
Post Date: 2007-10-30
noto View Drop Down
  Quote noto Quote  Post ReplyReply bullet Topic: Help overclocking x6800
    Posted: 30 Oct 2007 at 4:04pm
Im trying to over clock this system over 3.0ghz specs below:
Power Supply: 550W Thermaltake (SLI Compatible) (Silent PurePower Edition)
Processor: Intel Core 2 Extreme X6800 2.93GHz (1066MHz Front Side Bus) (4MB Cache)
Motherboard: Asus P5N-SLI (Chipset: nForce 570 Intel) (SLI Compatible) (Conroe)
Memory: 4GB DDR2 Super Talent at 667MHz
Video Card: nVidia GeForce 8800GTX 768MB (By: XFX) (PCI-Express)
Windows OS: Microsoft Windows XP Home
Cooling: Air Cooling (Certified Digital Storm Heat-sink and Fan (Stage 1 Cooling)
Also added a 120mm fan to the back to pull more out.
Any help thanks.
Edited by noto - 30 Oct 2007 at 4:10pm
william View Drop Down
  Quote william Quote  Post ReplyReply bullet Posted: 30 Oct 2007 at 5:39pm
is it just me or is it not a good idea to oc with Stage 1 Cooling?
if it was me i would not do this.
but good luck
Edited by william - 30 Oct 2007 at 8:05pm
commast View Drop Down
  Quote commast Quote  Post ReplyReply bullet Posted: 30 Oct 2007 at 7:18pm
You can OC your CPU with the Intel stock fan but you won't be able to OC that much. With your config you probably can get to around 3.2 or 3.3 MAX. There are plenty of guides on the Net that will show you how to OC your board. There's also an OC guide somewhere in this forum too.
Edited by commast - 30 Oct 2007 at 7:35pm
Tyler Lowe View Drop Down
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 30 Oct 2007 at 8:04pm
I would replace the stock CPU fan and thermal paste before doing anything else TBH.
  Quote william Quote  Post ReplyReply bullet Posted: 30 Oct 2007 at 8:15pm
yeah i know he is right this is what dso put on my pc
sundowner View Drop Down
  Quote sundowner Quote  Post ReplyReply bullet Posted: 30 Oct 2007 at 8:29pm
change the ram to 2x1066mhz instead of 4x667mhz and get a better heatsink.
Pro case with extra fan
Quad Q6600 2.4 OC'd 3.1!
Nvidia 8800GT
Asus Maximus Formula Mobo
2xgb 800mhz corsair
xfire - xuntiltheendx
