Help Please :(Post Date: 2013-01-05 |
| Author | |
Oreomadness
Joined: 28 Dec 2012 Online Status: Offline Posts: 6 |
Topic: Help Please :(Posted: 05 Jan 2013 at 2:55am |
Motherboard: ASUS Rampage IV Extreme X79 (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s) System Memory: 16GB DDR3 1866MHz Corsair Dominator Platinum DHX (Extreme-Performance) Power Supply: 800W Corsair GS (Dual SLI Compatible) Hard Drive Set 1: Operating System: 1x (240GB Solid State (By: Corsair) (Model: Neutron GTX Series) (SATA 6Gbps) Hard Drive Set 2: Multimedia\Data: 1x (2TB Western Digital (7200 RPM) (Model: Black Edition) (SATA 6Gbps) Optical Drive 1: Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Slim Slot Loading Edition) Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 2x SLI Dual (NVIDIA GeForce GTX 680 2GB (PhysX) (Overclocked EVGA) Sound Card: Creative Labs X-Fi Titanium HD 24-bit 96KHz 7.1 Extreme Cooling: Digital Storm Aventum Liquid Cooling System: CPU + Video Cards H20 Tube Color: Black Tubing with High-Performance Fluid (UV Lighting Reactive) Chassis Airflow: Digital Storm Aventum Automatic Response to Excess-Heat System (ARES) Internal Lighting: Digital Storm Aventum RGB LED Lighting System Enhancements: Digital Storm Aventum Integrated Side Panel Display Module Noise Reduction: Noise Suppression Package Stage 2 (Optimized Airflow & Fan Speeds with Noise Dampening Material) Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro/Deluxe/Saber tooth Motherboard) Windows OS: Microsoft Windows 7 Ultimate (64-Bit Edition) Power Supply: 800W Corsair GS (Dual SLI Compatible) Q1: Does the (800W Corsair GS) power supply have what it takes to support my configured system? Q2: What perks can i get from getting a power supply like 1200W Corsair Pro Platinum Series with Corsair Link or other PSU that have 1000W + |
Posted: 05 Jan 2013 at 3:56am |
Hi Oreomadness.... For oc' d sli 680s , audio card and the higher demanding x79 mobo I would go with the 1050hx. I never looked into Corsair Link but the HX has a 7 year warranty which speaks of its quality and is semi- modular, meaning only the 2 mobo cables are hard wired which makes for cleaner cable management and easier to swap out. The 1200w Corsairs are fully modular but are more than you need unless you went tri-sli or just wanted ' to make sure'.
Some will say 800w is enough but if a psu struggles you'll get crashes, re-sets, BSOD, etc and wonder if its the mobo, ram, etc before realizing the problem. The psu isn't the place to save a few bucks. Hope this helps.
Oreomadness
Posted: 05 Jan 2013 at 4:01am |
Helped Lots Thanks Dude I was really just thinking of the long run where i would save more money when it came to pay the electric bills.
Posted: 05 Jan 2013 at 5:13am |
In my morning haste, I forgot 2 things.
1. Nice rig.
2. I love oreo's dipped in milk.
Also, I'm not sure of the added juice needed for Aventum's monitoring and display systems like ARES. Good luck. |
