HELP! psu ?
Post Date: 2013-10-02
r3dness View Drop Down
  Quote r3dness Quote  Post ReplyReply bullet Topic: HELP! psu ?
    Posted: 02 Oct 2013 at 11:00am
Hi DSO,
I'm looking through your slade systems and I've configed it to these specs
Corsair Obsidian 550d Case
Asus sabortooth z87 motherboard
i7 4770k CPU
16GB DDR3 1600MHz Digital Storm RAM
DVD-R/RW/CD-R/RW optical drive
1TB western digital black caviar 7200rpm Hard Drive
GTX 760 2GB video card
Corsair H100i 240mm Radiator Liquid CPU Cooler
Stage 1: Overclock CPU 4.0GHz to 4.4GHz
Window 8    64bit
1)Is the (750W EVGA SuperNOVA Gold Rated) power supple enough to power this system?
2)If so, can this system to run BF3 (MULTIPLAYER!) at max/ultra settings without a hugh fps drop? **Trying to see if this system has what it takes to hold bf3 (MULTIPLAYER) at over 100fps and higher.**
thanks guys
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 02 Oct 2013 at 11:08am
You can keep the questions in one post.  Don't have to but sometimes its just easier to respond to. Big%20Smile
The 750W will run it no problem.
The gtx 760 should be able to max with BF3 if you game on a single 1920x1080 monitor or less.  Not sure about 100fps, but 60+ should work.  It won't with other heavier shooters, like Metro, Crysis warhead.
This page was generated in 3.222656E-02 seconds.
