Help Quick Please!
Post Date: 2009-10-02
poser View Drop Down
  Quote poser Quote  Post ReplyReply bullet Topic: Help Quick Please!
    Posted: 02 Oct 2009 at 11:24am
Looking to get a pair of headphones for a birthday present for my father in law, he has an Asus AM3 MoBo (not sure which one), and only uses onboard audio.  I'm looking at the Tritton AX Pro, which apparently might be an issue based on the connection it uses.  Can anyone tell me the likelihood that his Asus board has this audio output?
digital optical SPDIF
Thanks much in advance.
Antec 900
AMD 9950
Asus M3A
9800gtx+
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 02 Oct 2009 at 11:09pm
Most modern motherboards have the optical SPDIF output.
You can look on the back of the computer where the USB ports and whatnot are and look for a (generally the same on all) black square with a gray square inside of it.  In a dark/low-light room you should see red lighting around the edges of the gray square.
Synth3tikMessiah View Drop Down
  Quote Synth3tikMessiah Quote  Post ReplyReply bullet Posted: 03 Oct 2009 at 1:33pm
If you have that black plug (circled yellow) in the back of your chassis somewhere, you have the SPDIF output. Hopefully that helps some.
Edited by Synth3tikMessiah - 03 Oct 2009 at 7:42pm
Psimon View Drop Down
  Quote Psimon Quote  Post ReplyReply bullet Posted: 06 Oct 2009 at 7:57am
How much $$$ for the Tritton?
Might consider a pair of Sennheiser PC 350's. Very comfortable, great sounds,  regular audio & mic jacks. Drawback: they're pricey.
Edited by Psimon - 06 Oct 2009 at 7:57am
CM HAF 932*EVGA X58 3X SLI* i7920 4.0Ghz OC*6GB Mushkin RAM*EVGA Titan Sprclked*Samsung 850 Pro 1TB*Logitech Z5500*Razer Death Adder*Corsair 1000HX PSU*LG 34UM95 Monitor*Windows7Ult64
  Quote poser Quote  Post ReplyReply bullet Posted: 06 Oct 2009 at 9:49am
Thanks guys, I needed to order them when I was at work, so I wasn't able to look at the mobo.
I got the Tritton's for $154 shipped from the egg.  They have lots of connection options, he hasn't bought a sound card yet, so figured these might eliminate that need, or will work if he gets one.
Thanks!
Antec 900
AMD 9950
Asus M3A
9800gtx+
