Help
Post Date: 2010-08-14
Lava16 View Drop Down
  Quote Lava16 Quote  Post ReplyReply bullet Topic: Help
    Posted: 14 Aug 2010 at 11:50am
Hey all,
           I am just starting my search for a new machine and a friend of mine told me about DS and the quality work they do.I havent been into gaming in awhile(Getting married can do that).As an example of this Oblivion is the last game I installed.I probably wont be getting a lot of new games but the ones I do plan on getting would like to be able to play without a bunch of issues.I do not need to be running at max settings,just enough so I can enjoy myself without lots of stuttering.I currently have a 22' monitor and it runs in 1680 X1050.
Noe to the part that is making it hard,We now have a baby on the way so budget is a big issue.We would like to keep it around $1250 or so..I have ran quite a few builds but am so out of touch with today's technology,I figured I had better come here and seek help.I have no preference to any company regarding video or chipset.Thanks in advance for any help you guys can give me.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 14 Aug 2010 at 12:18pm
this is about as low as i could reccomend for a new gaming rig
you could do two things if you MUST lower the price more, drop the processor to an i7 750 and/or the video card to a 460 768MB version, in that order
  Quote Lava16 Quote  Post ReplyReply bullet Posted: 14 Aug 2010 at 1:30pm
I can go a bit higher if need to.Is there much difference between the 1333mhz memory vs the 1600?It is only $21 more and figure if it makes a difference might as well go for it.Thanks again.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 14 Aug 2010 at 1:48pm
eh not really, if you were going to spend more the first thing i would do is go to a gtx 470
  Quote Lava16 Quote  Post ReplyReply bullet Posted: 14 Aug 2010 at 3:01pm
ok,thanks again.
Raif View Drop Down
  Quote Raif Quote  Post ReplyReply bullet Posted: 14 Aug 2010 at 5:54pm
depends on the chip series, i5- i7 800 series it will make no difference.  i7 9 series minor differences that most people can't notice unless your doing lots multitasking. some cpu/mobos will require 1600 on the i7 9 series
2.5 Ghz Core duo
Nvidia 9500 gt
3 gb 1033 Mhz ram
[email protected]
