HELP!!
Post Date: 2007-12-26
Knives View Drop Down
  Quote Knives Quote  Post ReplyReply bullet Topic: HELP!!
    Posted: 26 Dec 2007 at 2:59pm
I just want to know if this will get me a good deal for the price. If you would change anything please tell me. One more thing I emailed them by putting my information on the bottom when I am configuring my com, but I can never get anyone to reply back. I am just wondering if I am doing it wrong or if there is another way to do it?
Case: Digital Storm Twister PRO (Black Anodized Aluminum Finish)
Power Supply: 620W Corsair HX (Dual SLI Compatible) (Silent Edition)
Processor: Intel Core 2 Quad Q6600 2.4GHz (1066MHz FSB) (8MB Cache)
Motherboard: nVidia 680i LT Core 2 Quad (By: eVGA) (nForce 680i SLI)
Memory: 4GB DDR2 Corsair at 667MHz (Dual Channel)
Floppy / Card: - No Thanks
Hard Drive 1: 160GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Hard Drive 2: 160GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Raid Option: Setup hard drive 1 and 2 in a Raid 0 Stripe (Read and Write Performance Boost)
Hard Drive 3: - No Thanks
Video Card: nVidia GeForce 8800GTX 768MB (By: eVGA) (PCI-Express)
TV Tuner: - No Thanks
Sound Card: Creative Labs Sound Blaster Audigy SE (Up to 7.1 Channel)
Physics Card: - No Thanks
Cooling: Air Cooled Stage 2 (Silent Artic Cooling Heat-sink (Copper Heatpipes)
Case Lighting: - No Thanks
Round Cables: - No Thanks
Overclock Processor: - No Thanks, Please do not overclock my processor
Windows OS: - No Thanks, Please test my memory, I will be responsible for software based support
Protection: - No Thanks
Pre-Install Game: - No Thanks
LCD Display: - No Thanks
Surge Shield: APC SurgeArrest Personal PER7 (7 Outlet) 120V Surge Protector
Speakers: Logitech 5.1 System (Black Edition) (Model X540) (Includes Subwoofer)
Bill the Cat View Drop Down
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 26 Dec 2007 at 3:37pm
Just a couple of points:
  1. 4 Gig of RAM is only marginally useful unless you're planning to install a 64-bit OS.
  2. Unless you are going to use this machine only for gaming and don't mind having to reinstall everything once in a great while, I'd add a third HD that's not part of the RAID0 and use it to store backup images of the system drive(s). Or do you have an external drive?
  3. This system would not be a great "overclocker" cause of the case & 8800 GTX ULTRA heat issues, the LT mobo, and the 667 MHz RAM, "not that there's anything wrong with that". It doesn't seem like you are leaning in that direction....
  Quote Knives Quote  Post ReplyReply bullet Posted: 26 Dec 2007 at 5:05pm
I am instaling a 64-bit OS, so you said do not get 4 gig of ram? I wasn't planing on overclocking, because it seemed like it would be fiine for me. Also I am not getting 8800 gtx ultra just the gtx. Can that overclock?
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 26 Dec 2007 at 11:39pm
No, I meant just the opposite. If you use a 64-bit OS, then 4 Gig is useful.
The ULTRA is an overclocked GTX, as far as I know. I believe overclocking GPUs produces only slight improvements. In general, I'm sure this configuration can be overclocked somewhat. It's just not going to produce extreme results.
So, sounds like all you need is some kind of backup drive, and you should be good to go....
This page was generated in 6.396484E-02 seconds.
