Help
Post Date: 2008-02-04
Thomas Lindemann View Drop Down
  Quote Thomas Lindemann Quote  Post ReplyReply bullet Topic: Help
    Posted: 04 Feb 2008 at 4:25am
I need some help with my desk top background. It wont allow me to change or save a different picture for a desk top. If you right click on the desktop then go to properties it doesnt even have a desk top index with the other selections. Oh any by the way I love my DS system works flawless.
Bill the Cat View Drop Down
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 04 Feb 2008 at 12:32pm
Vista, I presume?
  Quote Thomas Lindemann Quote  Post ReplyReply bullet Posted: 04 Feb 2008 at 12:38pm
XP
  Quote Thomas Lindemann Quote  Post ReplyReply bullet Posted: 06 Feb 2008 at 1:26pm
ANYONE?
Dashuu View Drop Down
Guest
Guest
  Quote Dashuu Quote  Post ReplyReply bullet Posted: 06 Feb 2008 at 1:32pm
To be honest, I've never heard of this problem. Josh tells me it can happen if your windows copy is corrupt. Try running a repair with the original windows disc. Go for the second repair, the one after you hit F8.
1
EdH63 View Drop Down
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 06 Feb 2008 at 1:39pm
Sounds like you may have the version... X "I Wannabe" P.  This was the version that had the feature that would limit your desktop options.
Ok, I'm a liar and this was not helpful.
Thumbs%20Down
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 06 Feb 2008 at 1:42pm
So, your Display Properties dialog box has tabs for Themes, Screen Saver, Apperance, and Settings, but not Desktop?
I Googled "Display Properties" Desktop tab and got some promising looking results. For example.
and this one:
"The truth is out there...."
Edited by Bill the Cat - 06 Feb 2008 at 1:46pm
