Help :/
Post Date: 2013-01-27
ZrZone View Drop Down
  Quote ZrZone Quote  Post ReplyReply bullet Topic: Help :/
    Posted: 27 Jan 2013 at 5:32pm
I really want to get a DS laptop because I'm constantly on the go; however i've owned about two laptops that weren't high end (actually low end) and i'm discouraged on if a DS laptop can handle high end games like battlefield, call of duty, crysis 2, Skyrim...etc. If there is anyone who owns a mid range DS laptop pls reply as soon as possible i really want to try and get one :(
DomTheBomb View Drop Down
  Quote DomTheBomb Quote  Post ReplyReply bullet Posted: 27 Jan 2013 at 7:14pm
Welcome to the forums!
If you could provide us with your budget that would help us find a laptop configuration that would fit your needs.
Digital Storm provides probably the best valued gaming laptops of any system builder. Unfortunately, how much you can spend on hardware will always determine what level of gaming you will get.
Every DS laptop will be able to play all of those games though, you may have to adjust some settings to get optimal framerates depending on what configuration you end up getting.
I do personally own a DS laptop and I absolutely love it. The laptop I own handles every game I play at high-ultra settings at a constant 60fps.
If you have any other questions about DS laptops feel free to ask.
DS x17, 1 Year 5 Months
i7 3720QM (2.6GHz/3.6GHz)
16GB 1600MHz DDR3
Nvidia GTX 680M 4GB
240GB Intel 520 SSD
Windows 8.1 Pro
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 29 Jan 2013 at 10:28pm
Higher end laptops will have no problem playing games, so no worries there. You do sacrifice mobility though, as they are heavier and have (comparatively) shorter battery life.
GeorgeH View Drop Down
  Quote GeorgeH Quote  Post ReplyReply bullet Posted: 31 Jan 2013 at 11:01am
ZrZ,
What Tid and Dom said. A properly-spec'd laptop will not have any trouble with demanding games. Right now, ten feet away from me, a friend is playing one of those modern FPS titles with all the settings cranked. The visuals are like looking through a window. No lag. No horizontal tears.
The trade-off is Portability vs Power.
Boards don't hit back. (Bruce Lee)
  Quote Alex Quote  Post ReplyReply bullet Posted: 31 Jan 2013 at 4:10pm
I agree with everyone else, our laptops can definitely rip through those games.
SnowandSand View Drop Down
  Quote SnowandSand Quote  Post ReplyReply bullet Posted: 31 Jan 2013 at 5:02pm
I went a little on the high end side today and purchased a x17E.  I can't wait to try it out on some FPS's... Bring on Crysis 3!
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 31 Jan 2013 at 5:55pm
Congrats! Awesome
  Quote Alex Quote  Post ReplyReply bullet Posted: 02 Feb 2013 at 3:51pm
Great! Thank you for choosing Digital Storm as well!
