HELP!!
Post Date: 2018-04-30
Foster View Drop Down
  Quote Foster Quote  Post ReplyReply bullet Topic: HELP!!
    Posted: 30 Apr 2018 at 4:24pm
Hey guys so im pretty excited, got my new comp today but... i load up dota or any game matter of fact and i cant move at all the frame rate is so bad its unreal.. anyone have some advice?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 30 Apr 2018 at 4:39pm
Sounds like you plugged your monitor into the motherboard graphic port and not the graphics card.    The graphics card might have removable plastic caps covering them .    Don’t use the graphics ports near the USB and audio ports.
Most cases have the graphics card below the rear fan.
Hope this helps.
  Quote Foster Quote  Post ReplyReply bullet Posted: 30 Apr 2018 at 5:47pm
okay ill try this out thanks!
  Quote Snaike Quote  Post ReplyReply bullet Posted: 30 Apr 2018 at 6:10pm
Red circle... no good. Those are the mobo connections.
GPU will be further down... yellow circle.
This is my Corsair 240T case Vanquish... your's may differ slightly.
  Quote Foster Quote  Post ReplyReply bullet Posted: 30 Apr 2018 at 6:12pm
problem fixed! thanks guys!
  Quote hoserator Quote  Post ReplyReply bullet Posted: 01 May 2018 at 1:56am
It happens a lot. Enjoy. Big%20Smile
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 01 May 2018 at 1:57am
