help
Post Date: 2008-09-26
will300 View Drop Down
  Quote will300 Quote  Post ReplyReply bullet Topic: help
    Posted: 26 Sep 2008 at 4:52pm
this is the comp i'm getting for my 18th b-day
Processor: AMD Phenom 9750 (2.4GHz) (Quad Core) (2 MB Cache) AM2+
Motherboard: NVIDIA 750a SLI (Chipset: nForce 750a SLI)
System Memory: 4GB DDR2 800MHz Corsair Dominator DHX (High-Performance)
Card Reader: - No Thanks
Hard Drive 1: 320GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Hard Drive 2: - No Thanks
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 280 1GB) (Includes PhysX Technology)
TV Tuner: - No Thanks
Extreme Cooling: Liquid Chilled FrostBite CPU & Dual Video Cards
Internal Lighting: Blizzard Internal Lighting (Red Edition) (Cold Cathode Tubes)
Modifications: NVIDIA Enthusiast System Architecture (ESA) System (Install, Test, Optimize Computer)
Boost Video Card: Yes, Overclock the video card(s) as much as possible with complete stability
Windows
OS: Microsoft Windows Vista Home Premium
Protection: - No Thanks
Benchmarking: 3D Mark Vantage Advanced Edition (By: Futuremark) (Pre-Install) (Vista Compatible Only)
Install/Test Game: Crysis (Pre-Install, apply updates, and test gameplay with my system)
LCD Display: Acer 19 inch (Widescreen) (Black Edition) (High-Value Display)
Speakers: Logitech 2.1 System (Black Edition) (Model S220) (Includes Subwoofer)
Keyboard: Wolf King Timber Wolf Gaming Keyboard (Black and White)
Mouse: Razer DeathAdder Gaming Mouse (High-Speed Gaming Grade)
what would be my processor,memory, and graphics be overclocked too?
does anyone know how i can get the comp delivered to me inside of a crate
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 4:59pm
dude I can't let you do that
here you go Ticket# 187560 --- Price: $3262 (To see this build click here)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 260 896MB (Includes PhysX Technology)
Modifications: - No Thanks
LCD Display: - No Thanks
will this setup will kill yours and it costs less
Edited by DST4ME - 26 Sep 2008 at 5:00pm
  Quote will300 Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 5:02pm
how fast would i be able to run crysis with your setup
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 5:04pm
not sure but with a q9550 OCed, and 2 x gtx 260 I don't see why you would have any problems with it, it should be just as fast as your setup if not faster I think.
  Quote will300 Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 5:05pm
what would your setups processor be overclocked to
  Quote will300 Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 5:07pm
and do you happen to know how i can get the comp delivered to me in a crate like costone got his delivered
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 5:11pm
crate is an extra 250. you request it when you call to place your order.
each processor is different so I can't tell you a clock speed, the q9550 I have see here are around 3.2 or 3.4. but the ones we see here are a small number of their customers.
you can go with 2 x gtx 280 if you like but the difference is very small, but the price will still be lower that your setup you have posted.
look at the top of the chart here:
you see how close the 2 x gtx 260 nad gtx 280 are.
Edited by DST4ME - 26 Sep 2008 at 5:12pm
MarkNY View Drop Down
  Quote MarkNY Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 5:15pm
19'' monitor?
I would buy 1 280 GTX.  SLI will prove to be not all that effective for a 19'' and you can always buy a 2nd card later, if you really feel you must.
I would go with (very similar to DST):
the below is around $3100.  The power supply may seem like a little overkill, but if you ever plan on buying a larger monitor and running SLI, you'll find it worth it.
System Memory: 4GB DDR3 1600MHz OCZ Platinum Edition
Video Card: NVIDIA GeForce GTX 280 1GB (Includes PhysX Technology)
Edited by MarkNY - 26 Sep 2008 at 5:20pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 5:22pm
MarkNY, the ram is not the same speed as the fsb.
if he wants 2 cards he needs the psu IMO.
but you are right, I his monitor resolution is not 1680 x 1050 or higher then he only needs one gpu.
he can find better price for monitor other places
Edited by DST4ME - 26 Sep 2008 at 5:23pm
  Quote MarkNY Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 5:23pm
p.s. in regards to your initial setup, I would not liquid chill the video cards and your cpu on one loop (I wouldn't even do it at all).  Your system will run WAY too hot with two 280 GTX and CPU OCed.  I would just liquid cool the CPU for a good OC and leave the video card(s) on air.  That way, you can add/remove/upgrade video cards in the future very easily.
DST- I chose 1600 mhz RAM b/c when they OC his CPU, they will likely bring the FSB up to 400 (his CPU does not have an unlocked multiplier since it is not an extreme edition, right?)
Edited by MarkNY - 26 Sep 2008 at 5:25pm
  Quote will300 Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 5:26pm
the only problem is that i don't know where to put the graphics card if i did want to upgrade it
  Quote MarkNY Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 5:32pm
Video cards are probably one of, if not the easier computer component to upgrade on your own, next to maybe RAM.  A CSR at digitalstorm could easily walk you through the process (or you could find a guide online).
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 5:38pm
@ will, Its very easy to add a GPU. DS phone support can help you, we can help you. its takes 2 seconds.
MarkNY, but that is a waste of ram, cause when no OC the extra speed can't be used but the price is much higher, it will not make a big enough difference in the q9550's OC speed.
yes you are right this not an extreme chip.
Edited by DST4ME - 26 Sep 2008 at 5:39pm
  Quote will300 Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 6:01pm
so which setup is better lol
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 6:49pm
go with mine but MarkNY has a good point, which I missed, if you resolution-is not at or over what we discussed go with one card, again your choice between 260 and 280 gtx, you should not see the difference.
here you go Ticket# 187664 --- Price: $2953 (To see this build click here)
Video Card: NVIDIA GeForce GTX 260 896MB (Includes PhysX Technology)
now that price can be lower, if you lower the cpu but I left the 1000w in there since you said you would add another one.
use the money saved to add a 500GB second HDD for media/personal files.
here is the same setup with 2HDDs
here you go Ticket# 187665 --- Price: $3027 (To see this build click here)
Edited by DST4ME - 26 Sep 2008 at 6:53pm
  Quote will300 Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 7:47pm
i forgot how to i get better resolution
Chris W. View Drop Down
Digital Storm Tech Support
  Quote Chris W. Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 7:51pm
We can help you with configuration of your monitor, and settings you do need help with that, my work number is in my signature if you have any questions you'd like to ask next week.
<img src="https://www2.razerzone.com/tag-generator/label_images/1222492484_2122770270.jpg" border="0" />
  Quote will300 Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 7:54pm
what if i were to get the 22 acer monitor then could i use sli for it
  Quote Chris W. Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 8:16pm
Yes, you would notice at 1900x1200 increase in performance there.
  Quote will300 Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 8:18pm
ok thank you
  Quote will300 Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 8:23pm
would i have to worry about my system being damaged if i don't let it get delivered in a crate?
  Quote will300 Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 8:24pm
ok heres the new system config with the crusher model that ds has
Chassis: Digital Storm 950Si
Windows
OS: Microsoft Windows Vista Ultimate (64-Bit Edition) (For Enthusiasts)
LCD Display: Acer 22 inch (Widescreen) (Black) (High-Performance Gaming Display)
Surge Shield: APC SurgeArrest Personal PER7 (7 Outlet) 120V Surge Protector
Speakers: Logitech 5.1 System (Black Edition) (Model X540) (Includes Subwoofer)
i think its good
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 8:30pm
no, my setup has a faster drive and a better case, go with mine, I'm telling you, check out our review section to see the HAF
like I said get your monitors and keyboard stuff from newegg you will find better prices.
go with vista premium not ultimate.
also if anything happens to your case during shipping you just send it back and they will fix it.
Edited by DST4ME - 26 Sep 2008 at 8:31pm
  Quote will300 Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 8:35pm
ok but i'm getting SLI and a 22 acer monitor what games do you play anyway dst do you play cs source
  Quote will300 Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 8:39pm
all i really want to play when i get the comp is crysis sandbox mod
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Sep 2008 at 8:42pm
I'm a power user boss not a gamer, I do my gaming on my ps3,wii or xbox.
search newegg and check out our hardware section for monitor suggestions
and besure to go with premium vista good luck.
widdlecat View Drop Down
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 27 Sep 2008 at 12:27am
Hahaha! I'm certain now that you're getting kickbacks for the HAF DST... LOL! Smile
Seriously though, that HAF is one nice case. It is well engineered for cooling and usability.
If you're truly concerned about shipping damage, you can talk with DSO over the phone and they can crate the box. Others have done this in the past, and the crate is solid! Extra charge for the crate of course.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Sep 2008 at 12:34am
LOL I knew you were gonna say that
Did you see Jeremiah.L's review of his new HAF? it look even better then I thought.
