Help?
Post Date: 2008-10-06
Blakhawk View Drop Down
  Quote Blakhawk Quote  Post ReplyReply bullet Topic: Help?
    Posted: 06 Oct 2008 at 11:49pm
Im pretty sure this is overkill but I'd like some other peoples opinions?
Suggestions? I really only do MMO's WoW, AoC, and some FPS BF2, CoD etc...
Chassis: Digital Storm 950Si
Exterior Finish: - EXOTIC StormBlack High-Gloss Automotive Paint Finish
Interior Finish: - EXOTIC StormBlue High-Gloss Automotive Paint Finish
Processor: Intel Core 2 Quad Extreme QX6850 3.00GHz (1333MHz FSB) (CLEARANCE PRICED)
System Memory: 4GB DDR3 1800MHz Corsair Dominator DHX (Extreme-Performance)
Card Reader: - No Thanks
Hard Drive 1: 1TB Western Digital (7200 RPM) (16MB Cache) (SATA) (Extreme Speed)
Hard Drive 2: - No Thanks
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Wireless Access: Bigfoot Killer Network Card (Features MaxFPS and UltimatePing Technology)
Video Card: NVIDIA GeForce GTX 280 1GB (Includes PhysX Technology)
TV Tuner: - No Thanks
Extreme Cooling: Liquid Chilled FrostBite Dual Loop System for CPU & Single Video Card Only
Internal Lighting: Blizzard Internal Lighting (Red Edition) (Cold Cathode Tubes)
Modifications: NVIDIA Enthusiast System Architecture (ESA) System (Install, Test, Optimize Computer)
Boost Video Card: Yes, Overclock the video card(s) as much as possible with complete stability
Tweak Windows: Yes, Disable and tweak all of the non-crucial services on the operating system
Windows OS: Dual Boot (Windows XP Professional & Windows Vista Ultimate (64-Bit Edition)
Protection: McAfee Internet Security (Includes: AntiVirus, FireWall and AntiSpyware)
Benchmarking: 3D Mark Vantage Advanced Edition (By: Futuremark) (Pre-Install) (Vista Compatible Only)
Install/Test Game: Age of Conan (Pre-Install, apply updates, and test gameplay with my system)
LCD Display: Samsung 24 inch (Widescreen) (Black) (High-Performance Gaming Display)
Keyboard: Microsoft Multimedia Desktop 3.0 (Multimedia Keyboard + Optical Wheel Mouse)
Warranty: 5 Year Platinum Care Extended Parts & Labor Warranty (Highly Recommended)
  Quote Blakhawk Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 12:03am
The interior finish is spossed to be red btw
Tyler Lowe View Drop Down
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 1:17am
I would probably make my build closer to this.
If you want to go with an extreme chip, IMO, the only reason to do so is to get as close to the next generation of CPU's performance as possible- in other words, to be on the bleeding edge. Once that next generation is released, the newer chips in the upper sku numbers are going to beat an older extreme chip like the QX6850. The Q9650 is simply a better performer at a lower price.
I took the 1600MHz RAM over the 1800MHz.The price difference is fairly large, and it seemed better to put that budget towards some other upgrades. 1800Mhz RAM can make a higher overclock more attainable, but with 1600MHz RAM you should be able to hit 3.8 to 4.0GHz if the CPU and motherboard will do it. 1800MHz RAM may tip the odds in favor of a 4GHZ OC a little higher, but nothing is garanteed. You could get a CPU that won't go higher than 3.6 GHz. It's luck of the draw.
I dropped the Network card in favor of adding a second GTX280. The network card is extremely situational and offers marginal performance gain. The second GTX is anything but and offers substantial gains. I did consider an SLI pair of GTX260, but given the budget you're working with, discarded that idea. The GTX260 offers a similar texture fill rate, but lacks the memory bandwidth and frame buffer size of the better card.
I also ditched the security software. I've never cared for McAffee (I did use it for a couple of years). I find it process heavy and while this may seem petty, I did not care for the popups starting 5 months from the time my coverage was due to end asking me to renew my subscription. That's a bit like seeing Christmas decorations up in stores before Halloween. It happens every year and never fails to piss me off. After trying Norton Pro, McAffee, Zone alarm Pro SS, and AVG, I finally settled on ESET and have been very pleased with it. ESET doewsn't care if you have the program installed in two OS either. You still pay only for one liscense key which is a definite plus.
I replaced your single TB harddrive with a VR 300GB and a seperate 750GB HDD. You will find this gives you better performance, easier disk maintenance, and gives you the same storage capacity.
Unless you really, really, *really* like tweaking and overclocking your own system, ESA is nothing I would spend money on. Again, I'd rather put it towards more garanteed return on my investment - faster HDD, SLI, better cooling- anything really. In looking at your configuration, you selected virtually every OC and tweaking option offered by DSO. My thinking was that if you were someone that would gain any real advantage from ESA, you would be doing these tweaks and the overclocking on your own. If I'm wrong there, my apologies, but it seemed lik another easy place to save some cash.
I removed the monitor and the keyboard. Both can be ordered seperately online at lower cost. The 24" monitor offered on the configuration page is $549. For the same price, you can get a 26" monitor from the same manufacturer at Newegg. You could also just pocket the $100 and get the same 24" monitor for about $429.
For the keyboard and mouse, those are very personal choices. if you are looking for a recomendation, I prefer the Logitech G15 gaming keyboard and the Razer Lachesis gaming mouse.
Edited by Tyler Lowe - 07 Oct 2008 at 1:20am
  Quote Blakhawk Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 1:26am
Thanks, I will definitely take this into consideration. I really regret paying $5000 for my Alienware a few years back. Thing is in shambles now XD
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 5:41am
you can't beat this, unless you get a higher cpu
here you go Ticket# 191854 --- Price: $4427 (To see this build click here)
Processor: Intel Core 2 Quad Q9650 3.0GHz (1333MHz FSB) (12MB Cache)
Motherboard: Asus P5E3 Premium WiFi-AP (Intel X48 Chipset) (Supports CrossFire)
Video Card: ATI Radeon HD 4870X2 2GB
Extreme Cooling: Liquid Chilled FrostBite Dual Loop System for CPU & Dual Video Cards
Modifications: - No Thanks
Protection: - No Thanks
LCD Display: - No Thanks
do you know how to OC your graphic card?
btw, Alienware sucks.
if it wasn't for the touch sensor I would put you in a cosmos s.
Edited by DST4ME - 07 Oct 2008 at 5:44am
  Quote Blakhawk Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 2:34pm
Thanks, and no I dont really know much about overclocking since I wouldnt dare OC my laptop haha. Would going for two radeons be worth it? (Id think so... I mean 4 GPU's? Come on haha.)
  Quote Blakhawk Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 2:54pm
Or what about something like this? http://www.digitalstormonline.com/comploadsaved.asp?id=191854
Only around $5000
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 5:23pm
great build but if you don't oc the gpus then drop the liquid cooling, they dont need ocing, some gpu enthusiest like to co, me and you are not one of them so we need to liquid cool only the cpu
I have to disagree with HM on memory oc, you should get it so you have more stable OC and you get the ram fan
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 11:19pm
You'd have to ask if liquid cooling is available for the 4870x2 if you'd rather stick with that over air cooling. If it is, my guess would be you'd be charged as though it is two cards since it would require two cooling blocks, not one- one for each GPU.
Lawdog View Drop Down
  Quote Lawdog Quote  Post ReplyReply bullet Posted: 08 Oct 2008 at 3:10am
Actually TL I think it's just one water block.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Oct 2008 at 4:09pm
HM I don't think that is the case otherwise DS would be misleading people
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 08 Oct 2008 at 11:58pm
Thanks for that link Lawdog. Another new thing learned today. Always good to have the straight poop.
RAM timings have to be adjusted when you overclock, but you don't neccesarily have to spend any time tweaking those back to their tightest possible settings once you achieve a stable CPU overclock. I generally don't bother with it myself. It's time consuming and doesn't do much in terms of performance outside of synthetics. So I guess you're both right. The only reason to ask for a RAM OC if you're having your CPU overclocked is for the fan IMO, and it does entail more than just overclocking the CPU.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 Oct 2008 at 12:03am
DS themselves say, if you don't OC the ram they will not adjust the ram for nothing.
