Help!
Post Date: 2020-05-14
Menacely View Drop Down
  Quote Menacely Quote  Post ReplyReply bullet Topic: Help!
    Posted: 14 May 2020 at 7:54pm
So my PC Lynx Ultimate is supposed to arrive tomorrow what’s the first thing/things I should do before playing as this is my first gaming PC?
John18 View Drop Down
  Quote John18 Quote  Post ReplyReply bullet Posted: 14 May 2020 at 9:59pm
Get your Windows up and running, get your antivirus running, make a backup if you have a program and external HDD, get your browser customized, get programs installed...should I go on?
Normally I expect a new computer to take up to two days to be ready for me to have programs installed, data migrated, etc.
  Quote Menacely Quote  Post ReplyReply bullet Posted: 14 May 2020 at 10:47pm
Holy sh*t that sounds like a lot 2days So I can’t play it for 2days?
Edited by Menacely - 14 May 2020 at 10:51pm
  Quote Snaike Quote  Post ReplyReply bullet Posted: 15 May 2020 at 2:46am
Well, you can play as soon as you download your games.. the machines are ready to be used. You just have to make sure that you're ready to start downloading stuff in a safe and sane manner.
Good luck!!! and Have Fun!!
  Quote Cretae Quote  Post ReplyReply bullet Posted: 15 May 2020 at 4:41am
John18 probably has a lot of housekeeping bringing over files and programs from his existing set-up. IIRC. this is your first PC, so you can jump right in! If you're using Windows Security, click on the windowpane in the lower left, or press the windowpane key on your keyboard. The list that opens is alphabetical, so Windows selections are near the bottom. Click on Windows Security, and see if the items are checked. They should be on by default. Once you are sure you're protected, you can do anything you want!
