help to customize a desktop
Post Date: 2013-10-22
lvisa View Drop Down
  Quote lvisa Quote  Post ReplyReply bullet Topic: help to customize a desktop
    Posted: 22 Oct 2013 at 8:37pm
I have a Dell U2412 Monitor, keyboard is black widow, mouse is Death adder, I just want to use the computer to play Crossfire, my budget is less than 1000 USD. Can anyone help me out? I have no idea how to customize a desktop...
Nav View Drop Down
  Quote Nav Quote  Post ReplyReply bullet Posted: 22 Oct 2013 at 8:56pm
I assume you are talking about Crossfire F2P?
If so, a Vanquish Lv 1 or Lv 2 would be perfect for you and are under $1000.
Vanquish
Level 1
Level 2
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 22 Oct 2013 at 10:08pm
^ Best options for your budget...
  Quote lvisa Quote  Post ReplyReply bullet Posted: 23 Oct 2013 at 11:08am
Thank you! I was also looking at this one~
  Quote lvisa Quote  Post ReplyReply bullet Posted: 23 Oct 2013 at 11:09am
yeah~ someday maybe
Ariktu View Drop Down
  Quote Ariktu Quote  Post ReplyReply bullet Posted: 23 Oct 2013 at 3:08pm
My advice would be to see if you can stretch your budget to get the Level 3.
It is a small amount more than your existing budget, but the upgrades are pretty large if you can find a way to swing it.
Good Luck!
  Quote lvisa Quote  Post ReplyReply bullet Posted: 23 Oct 2013 at 9:16pm
[QUOTE=Ariktu] My advice would be to see if you can stretch your budget to get the Level 3.It is a small amount more than your existing budget, but the upgrades are pretty large if you can find a way to swing it.Good Luck!
Thank you for consideration but I really not a fan of 3D games, isn't level 2 is already enough for Crossfire?
  Quote Ariktu Quote  Post ReplyReply bullet Posted: 23 Oct 2013 at 10:57pm
It is just the GTX 760 is a nice video card upgrade plus the level 3 comes with a larger Power Supply which can be nice if you ever upgrade anything.
Add in the better CPU and it really is a great value if you can manage it.
obviously if you have zero need for those upgrades I would stick with the level 2 system.
Nav View Drop Down
  Quote Nav Quote  Post ReplyReply bullet Posted: 23 Oct 2013 at 11:28pm
If you just plan on just playing Crossfire and not more demanding games like Battlefield 4, the Level 2 will have more than enough power.
Edited by Nav - 23 Oct 2013 at 11:29pm
