Help- transitioning from console
Post Date: 2018-09-23
Dwxyne View Drop Down
  Quote Dwxyne Quote  Post ReplyReply bullet Topic: Help- transitioning from console
    Posted: 23 Sep 2018 at 7:45am
Ok so I’m coming from console and I’m completely new to this PC stuff and I don’t think I can spend $1,000+ on a rig, so how is the DS Vanquish Level 1 for playing games like CSGO or maybe PUBG? I know pubg won’t run as well as csgo (unless it will) but will csgo run at a stable 60 FPS? I’m not looking for anything crazy right now like 200 FPS. Since I’m coming from console 60 is good enough for me. I’m just looking for the keyboard and mouse experience, ya know? And final thing, any suggested monitors? Not looking for anything huge either. Thanks!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Sep 2018 at 1:56pm
The level is a good entry level gaming system.    You could play those games on a 1080p monitor but might have to lower game settings for decent frames.
Problem is, the level 1 doesn’t have a graphics card, but uses the cpu processor built in , integrated graphics.
It does allow for a graphics card to be installed whenever needed. The gtx 1060 would be a huge bump in gaming.
I can’t say what frames you’ll get with PUBG.   Google VEGA 11 for the games you play and see what testers are getting.   VEGA 11 is the integrated graphics.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 17 Oct 2018 at 3:45pm
+1
It is an easy upgrade installation. There are two 1060 cards, get the one with the higher memory, I think it's 6Gb.
Big%20Smile
Edited by hoserator - 19 Oct 2018 at 2:35am
This page was generated in 2.148438E-02 seconds.
