Help troubleshoot my microphone?
Post Date: 2008-12-06
67alecto View Drop Down
  Quote 67alecto Quote  Post ReplyReply bullet Topic: Help troubleshoot my microphone?
    Posted: 06 Dec 2008 at 10:42pm
Ok, finally getting around to getting a new microphone - haven't had one in years, but Left 4 Dead is pretty sweet with voice interaction.
Just bought a microphone specifically for computers - even has the jack insert labled pink to match the standard color-coding.  It's an open mic - no push-to-talk buttons.
So, I have the X-fi gamer card with the pink microphone jack.  I plug the microphone in and I get nothing.
Running WinXP, SP3
What I've checked so far:
Under Volume Control>Playback the microphone is not muted
Under Volume Control>Recording control - only the microphone is selected.  Under the advanced properties, I've both checked and unchecked the +20db Microphone boost
Under the creative audio console, I don't have anything to setup a microphone
Under Control Panel>Sounds and Audio Devices>Voices and Audio Tabs, the microphone set as SBX-FiAudio.  In running the hardware test there, it doesn't pick up anything when I read the test paragraph
Using Audacity, I can't get it to pick up anything I say
Using Windows Sound Recorder, I can't get it to pick up anything I say
As an interesting side note, if I play an MP3 with the microphone plugged in, both Audacity and Sound Recorder will capture a distorted/garbled portion of the song.  Unplugging the mic drops the input to zero.
Having the microphone plugged in during MP3 playback causes distortion in the song, which can be increased or decreased depending on the volume setting of the mic in the volume control panel.
In Left 4 Dead, there's an option to test your mic - it doesn't pick up any sound.
Any suggestions?
Twister Pro
750W PS/Q6600 2.4GHz/680i LT/2GB Corsair 800/9800GTX/X-Fi XtremeGamer/Stage 2 Cooling
Vanquish II
430W Corsair/i3 3.3 GHz/Asus H61M/8Gb DDR3 Corsair Vengeance/650Ti Boost 2Gb
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 06 Dec 2008 at 11:07pm
reinstall drivers?
turn on "Audio Creation Mode"?
  Quote 67alecto Quote  Post ReplyReply bullet Posted: 07 Dec 2008 at 12:27pm
I reinstalled last night - including all of the creative suite from the installation disk.
No dice.
I emailed the same question to Creative, but they said I was SOL (unless I wanted to pay for support help) since I bought my computer on 9/7/07.
Twister Pro
Vanquish II
Rad!caL View Drop Down
  Quote Rad!caL Quote  Post ReplyReply bullet Posted: 07 Dec 2008 at 7:49pm
Make sure you have the proper recording setting selected in CP>Sound (there are quite a few).
Raise the mic level in the Creative Mixer panel.
jtspectra2 View Drop Down
  Quote jtspectra2 Quote  Post ReplyReply bullet Posted: 07 Dec 2008 at 8:06pm
maybe your mic is broken
  Quote 67alecto Quote  Post ReplyReply bullet Posted: 08 Dec 2008 at 1:57pm
Thanks everyone for taking a look at this.  Here is a summary of replies:
Are you connecting to your sound card,mobo,or front /Top header?
I'm connecting to the soundcard
I've set it to max, and it doesn't pick up anything
Yeah, there's always this.  I've ordered a USB mic from newegg as a precaution, but it's pretty odd that I get such interference with sound playback when the mic is plugged in.
Twister Pro
Vanquish II
  Quote 67alecto Quote  Post ReplyReply bullet Posted: 08 Dec 2008 at 5:02pm
Have you tried the front header..It is more than likely connected thru your mobo..
As soon as I got home, I traced the wires coming from the front and saw it.  Got it working now.
Thanks, man
Edited by 67alecto - 08 Dec 2008 at 5:03pm
Twister Pro
Vanquish II
