help w/ config. for newbie
Post Date: 2009-03-12
biLLythek1d View Drop Down
  Quote biLLythek1d Quote  Post ReplyReply bullet Topic: help w/ config. for newbie
    Posted: 12 Mar 2009 at 11:09pm
Hey All,
I have a little over $2k to spend on a new computer for gaming/video editing.  What do you guys think of this config?  Would appreciate any advice.  Thanks.
Total $2378 before final discount
Motherboard: CLEARANCE HOT SELLER: ASUS P6T Deluxe (Intel X58 Chipset) (Supports Dual SLI or CrossFire)
System Memory: 6GB DDR3 1600MHz Corsair Dominator DHX (High-Performance)
Hard Drive Set 1: Operating System: 1x (1TB Western Digital (7200 RPM) (16MB Cache) (SATA) (Extreme Speed)
Video Card: 1x NVIDIA GeForce GTX 260 896MB (216 Cores) (Includes PhysX Technology)
LCD Display: - No Thanks
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 Mar 2009 at 11:26pm
295 gtx system:
here you go Ticket# 258371 --- Price: $2471 (To see this build click here) Price after current promotion $2321
System Memory: CLEARANCE HOT SELLER: 3GB DDR3 1333MHz Corsair XMS3
Card Reader: - No Thanks
Video Card: 1x NVIDIA GeForce GTX 295 1.792GB (Includes PhysX Technology)
above system with 6GB of ram = $2708 Price after current promotion $2533
260 gtx system:
here you go Ticket# 258372 --- Price: $2141 (To see this build click here) Price after current promotion $1991
above system with 6GB of ram = $2378 Price after current promotion $2228
there is 4 systems for you to consider
  Quote biLLythek1d Quote  Post ReplyReply bullet Posted: 13 Mar 2009 at 11:42am
Thanks for the help? Is it worth it to buy 1600MHz ram vs. 1333MHz ram? Does it help with overclocking?  Do I need to buy larger than a 750W power supply if I don't plan on using SLI?
Edited by biLLythek1d - 13 Mar 2009 at 11:53am
Perlife View Drop Down
  Quote Perlife Quote  Post ReplyReply bullet Posted: 13 Mar 2009 at 11:54am
stay with the 1333MHz... and if you want to upgrade your GPU later (be future proof) you need a 1000W Power Supply
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Mar 2009 at 4:13pm
you won't notice the difference between 1600 and 1333MHz ram.
if you don't plan to sli in the next 4 years then no you don't need a 1000w, but if you plan on more gpu power you will need the 1000w.
