Help with 3k build
Post Date: 2013-06-12
zoihsai View Drop Down
  Quote zoihsai Quote  Post ReplyReply bullet Topic: Help with 3k build
    Posted: 12 Jun 2013 at 8:50pm
2-3k
Great Gaming rig that will be future proof for about 5 years
hardcore gaming and music/movie storage and watching
Is this build solid for my needs? any overkill that i can cut back on to save a few bucks?
Chassis Model: Special Deal Hot Seller - Digital Storm VIRTUE
Processor: Intel Core i5 4670K 3.40 GHz (Unlocked CPU) (Quad Core)
Motherboard: ASUS Z87M-PLUS (Intel Z87 Chipset) (MATX)
System Memory: 16GB DDR3 1866MHz Corsair Dominator DHX (High-Performance)
Hard Drive Set 1: Operating System: 1x (480GB Solid State (By: Corsair) (Model: Neutron GTX Series) (SATA 6Gbps)
Hard Drive Set 2: Multimedia\Data: 1x (3TB Western Digital/Seagate/Hitachi/Samsung (7200 RPM) (SATA 6Gbps)
Video Card(s): 1x NVIDIA GeForce GTX 780 3GB (Includes PhysX)
Extreme Cooling: H20: Stage 1: Corsair H60 Liquid CPU Cooler (High-Performance Edition)
Chassis Airflow: Upgrade All Fans to Corsair Airflow 140mm Performance Edition (Up to 6 Fans)
Windows OS: Microsoft Windows 8 (64-Bit Edition)
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 13 Jun 2013 at 3:15am
Hi zoihsai... Welcome to the forums.    The build looks good.    If you want to save a few bucks then go with standard ram.   The higher heat spreaders is more for looks and the faster clock you'll never see. Standard DS at 1600mhz is fine.    For gaming, 8 gb is all you need.
Also, unless you plan on adding another video card in sli, the evga 750 supernova is all you need.
Grab the free t-shirt.   Looks great and good luck.
Edited by bprat22 - 13 Jun 2013 at 5:51am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 13 Jun 2013 at 5:52am
Also, just noticed, the Plus motherboard in your config can't sli, so the smaller psu would do it.  If you want sli capability then go with the Gryphon.
Nerek387 View Drop Down
  Quote Nerek387 Quote  Post ReplyReply bullet Posted: 13 Jun 2013 at 10:47am
If your going to be gaming also, go with the i 5 3570k or the i 7 3770k, i5 3570k will work great for you and is a little cheaper, the i 7 is a better cpu however a little more expensive, both will work better for gaming over the 4670k.
Edited by Nerek387 - 13 Jun 2013 at 10:49am
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 13 Jun 2013 at 8:40pm
Got to get the t-shirt. It is the best part of a custom killer build. You need to be able to represent when you are in public.
  Quote retirednavysnipe Quote  Post ReplyReply bullet Posted: 14 Jun 2013 at 7:38am
Looks like a great build. Good Luck and welcome to the forums and to the Digital Storm family.
Hailstorm Black Ops
I7 3930K 4.5GHZ
16GB 1600MHZ ram
2 x GTX 680
120 GB SSD, 1 TB hardrive
