Help with build
Post Date: 2007-11-15
Bero View Drop Down
Guest
Guest
  Quote Bero Quote  Post ReplyReply bullet Topic: Help with build
    Posted: 15 Nov 2007 at 1:34pm
hello, i am looking for some help. I am trying to configure a semi- hardcore gaming machine from DS, i have around $ 4,000 any help would be appreciated. Such as maybe i have to much of something? Downgrade to upgrade another part just let me know Wink here is the system. I am also going to be asking DS to overclock the hell outta this machine LOL so just wondering from the DS mods what i might expect from the overclocking (cpu, gpu, memory)
Case: digital storm twister ultra
Power supply: 750W silverstone ilympia
Processor: intel core 2 quad 2.4 ghz
Motherboard: nVidia 680i LT core 2 quad (By: eVGA)
Memory: 4GB DDR2 Corsair at 800 mhz XMS2
Hard Drive 1: 74g WD raptor (10k rpm)
Hard Drive 2: 250g WD
Optical drive 1: DVD-rom/CD-rom
Optical drive 2: dvd-r/rw/cd-r/rw
Video Card: Geforce 8800 Ultra 768 mb (By:eVGA)
Cooling: Liquid chilled CPU and Video Cards
Case Lighting:Blue
Cabling: Enhanced Air Flow (black)
OS: Vista Ultimate 64 bit
gdhart View Drop Down
  Quote gdhart Quote  Post ReplyReply bullet Posted: 15 Nov 2007 at 2:05pm
You should upgrade to the nVidia 680i core 2 quad (By: eVGA) A1Revision MoBo as you will get a better overclock and it includes 2 USB headers on the MoBo and 6 USB ports on the back.
Also, if you are looking for a higher over clock on the CPU you might want to go with the 1066 Dominator RAM.
Making these 2 changes will get you to $4027.  I you change the memory to 2 Gig of 1066 Dominator it will then come in at $3777.
850W PSU/Pro Case
Q6600-G0 2.7GHz
nVidia 680i A1 Revision
4GB 800MHz XMS2
1x500 GB WD, 2x500GB WD RAID-1
2x500GB Ext
nVidia GeForce 8800GTX 768MB
ATI TV Wonder 650
Air Cooled Stage 3
Bero View Drop Down
Guest
Guest
  Quote Bero Quote  Post ReplyReply bullet Posted: 15 Nov 2007 at 2:10pm
Alright cool thanks, also i was wondering should i bother getting dual video cards for SLI. I was thinking of getting dual 8800 GTX what do you think?
Bigdog View Drop Down
  Quote Bigdog Quote  Post ReplyReply bullet Posted: 15 Nov 2007 at 2:47pm
you might as well go dual 8800GT or you could get 1 8800GT 512MB and stick with that for awhile.  Something better usually comes along and you might want to replace it and go dual (something else).  I don't believe SLI is really important right now.  A lot of people are just going with 1 graphics card.  You could probably get just one 8800GTX and you will be perfectly fine.
Is there any reason why you need "Vista Ultimate"?  You could just stick with Windows Premium 64bit, it will be cheaper to do that.
I guess this is my opinion, but you really don't need to liquid cool your GPU's unless you are planing to do something with them?   From what I heard when talking to Dave at DSO, liquid cooling your GPU's makes it that much more of a pain in the butt when you need to change GPU's.  If I were you, I would just stick with liquid cooling for the CPU ONLY.
that will give you extra money to maybe add other things that could improve the overall performance on your computer.
Edited by Bigdog - 15 Nov 2007 at 2:59pm
Processor: QX6850 (3.3Ghz)
RAM: 4GB 1066 Dominators
Graphics: 2x 8800GTX 768MB
Sound Card: Fatal1ty
HDD 1: 2x 150GB raptor (RAID 0)
HDD 2: 1x 150GB raptor
HDD 3: 320GB western
Liquid cooling (red)
  Quote Bigdog Quote  Post ReplyReply bullet Posted: 15 Nov 2007 at 3:05pm
This might work? Not sure, but you may like it, if you want liquid chilled CPU only.
$3,720.00
Case: Digital Storm Twister ULTRA (Black Anodized Aluminum Finish)
Power Supply: 750W SilverStone Olympia (Dual SLI Compatible) (Model: OP750) (Silent)
Processor: Intel Core 2 Quad Q6600 2.4GHz (1066MHz FSB) (8MB Cache)
Motherboard: nVidia 680i Core 2 Quad (By: eVGA) (nForce 680i SLI) (A1 Revision)
Memory: 4GB DDR2 Corsair at 1066MHz Dominator (Dual Channel) (Extreme-Performance)
Floppy / Card: Digital Media Card Reader (Black)
Hard Drive 2: 150GB Western Digital Raptor (10K RPM) (16MB Cache) (SATA) (Extreme Speed)
Raid Option: Setup hard drive 1 and 2 in a Raid 0 Stripe (Read and Write Performance Boost)
Hard Drive 3: 250GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Video Card: nVidia GeForce 8800GTX 768MB (ACS3 Overclocked Edition) (By: eVGA)
TV Tuner: - No Thanks
Sound Card: Motherboard Multi-Channel High Definition Audio (7.1 Channel)
Physics Card: - No Thanks
Cooling: Liquid Chilled CPU Only (Phantom Black Liquid)
Round Cables: Enhanced Interior Air Flow (Optical Drive & Floppy Cables (Black Edition)
Protection: - No Thanks
Pre-Install Game: - No Thanks
LCD Display: - No Thanks
Keyboard: Razer Lycosa Gaming Keyboard
Mouse: Razer DeathAdder Gaming Mouse (High-Speed Gaming Grade)
You can definitly go with a different case, like the EXTREME case.  I would highly suggest them.  If you want to upgrade in the future these cases are big enough if you are doing some BIG upgrades.  the Ultra case and EXTREME cases are bigger so I guess the cooling is a lot better in them as well.
If you don't need a keyboard or mouse then take those off and you will save some more cash.
Edited by Bigdog - 15 Nov 2007 at 3:08pm
Bero View Drop Down
Guest
Guest
  Quote Bero Quote  Post ReplyReply bullet Posted: 15 Nov 2007 at 3:15pm
alright thanks for the input. I wanted water cooling for the GPU cause i was going to overclock it, and i didn't want to hear the fans on high and it seemed to me it would keep it cooler. I am running vista ultimate cause i plan on keeping this machine for awhile and sooner or later going to have to upgrade
  Quote Bigdog Quote  Post ReplyReply bullet Posted: 15 Nov 2007 at 3:58pm
ooooh! I see, hehe ok.  OMG, I didn't notice you had the ultra case already in your config ***smacks self in the head*** stupid me.  For me not to pay attention, please excuse me since I am burnt out on laziness for the past week.  I am kind of like a zombie right now.
Edited by Bigdog - 15 Nov 2007 at 4:00pm
Bero View Drop Down
Guest
Guest
  Quote Bero Quote  Post ReplyReply bullet Posted: 15 Nov 2007 at 4:08pm
lol, no need to apologize you are helping me. So i should prob just run one video card... you think i should get the GTX instead of ultra? I heard the ultra is just an overclocked GTX.
OlBull View Drop Down
  Quote OlBull Quote  Post ReplyReply bullet Posted: 15 Nov 2007 at 4:22pm
For what it's worth.  I had many questions prior to placing my order also.  So I called DS and Dave and I went right down the list of components I thought I wanted, and he explained/answered/confirmed or made recommdations for each question I had.  The final product I ordered was modified a bit, and was actually a little less cost than what i had originally planned.  I'd call DS, cuz I'm convinced they'll not steed you wrong.
I was totally impressed!
Bero View Drop Down
Guest
Guest
  Quote Bero Quote  Post ReplyReply bullet Posted: 15 Nov 2007 at 5:23pm
alright ill do just that, thank you!
This page was generated in 7.177734E-02 seconds.
