Help with Choosing External Hard Drive
Post Date: 2009-11-14
Page  123>
B5GkarNarn View Drop Down
  Quote B5GkarNarn Quote  Post ReplyReply bullet Topic: Help with Choosing External Hard Drive
    Posted: 14 Nov 2009 at 2:07pm
I currently have a 100 GB USB portable external hard drive that I use to backup my current PC that only has an 80 GB internal hard drive.  My new DS rig (that is coming next week) has 2 internal hard drives: a 500 GB &  1 TB.
1) Therefore, what size/type/brand,etc. of external hard drive should I get for my new DS rig?
Please note that I like the small size of the portable external hard drives because I have very liitle space but I don't think that they come in larger sizes than 640 GB.
2) Are there any portable external hard drives larger than 640 GB?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Nov 2009 at 3:54pm
make your own
click on clone guide in my sig, and then at the bottom of my post in the clone guide you will see links for HDDs and external enclosures, look for one that has a fan.
  Quote B5GkarNarn Quote  Post ReplyReply bullet Posted: 15 Nov 2009 at 7:14pm
Originally posted by DST4ME
make your own
How do I choose the correct HDD and external enclosure out of all of the different options that are in those links?
e06028 View Drop Down
  Quote e06028 Quote  Post ReplyReply bullet Posted: 15 Nov 2009 at 7:21pm
I just bought this one and it works really great.  It has a fan and can handle a 1.5 TB hard drive.  It also has esata which is faster than USB. It only holds one hard drive.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817709026
Optimystic View Drop Down
  Quote Optimystic Quote  Post ReplyReply bullet Posted: 15 Nov 2009 at 9:57pm
I believe Western Digital and possibly Seagate both make a 1TB portable hard drive. There's some advertised in the local Best Buy ad this week, actually.
Coolermaster Haf932
i7 920 oc'd to 3.75ghz
12gb mushkin 1600mhz ram
GTX 275 896mb video card
Razer Barracuda
150gb Velociraptor
1TB Seagate
1000w Corsair psu
Frostbite liquid cooling
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 12:29am
@Optimystic, we are talking about making your own external drive which is much much better then getting one that wd or seagate makes and cheaper most times.
@e06028, how long have you had that? looks good
  Quote Optimystic Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 12:35am
I know but he said he was interested in staying with the smaller portable drives. didn't know you could make one of those yourself. Just trying to help.
Coolermaster Haf932
Razer Barracuda
150gb Velociraptor
1TB Seagate
1000w Corsair psu
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 12:44am
portable drives are nothing but a HDD in an external enclosure, you just go buy your own HDD and external enclosure. they will be the same size, as a matter of fact some of my own is smaller then the ones that are already made.
I"m just sharing info, hope I didn't come across the wrong way.
Edited by DST4ME - 16 Nov 2009 at 12:44am
  Quote e06028 Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 12:28pm
I have had it for about 2 weeks and the performance is great.  The fan is a great feature.  I take it to work with me so I can keep all my important stuff on the external drive.  So far so good and it has not had a problem so far with me carrying it around.
Also I have had the portable ones before and they just don't last very long which is why I switched to an enclosure.
Edited by e06028 - 16 Nov 2009 at 12:30pm
EdH63 View Drop Down
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 12:38pm
So, I'm thinking about getting this.  It seems pretty simple in it's form.  You just plug into a USB port on the PC and that's it?
Edited by EdH63 - 16 Nov 2009 at 12:41pm
  Quote e06028 Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 12:50pm
Once you put in the hard drive and plug it in you will have to go to disk management and assign it a drive letter.  Installation of the hard drive was so easy a caveman can do it.  I bought the Seagate Barracuda 1TB hard drive to put in the enclosure.  I use the esata port and it works great, I can also see the temperature of it when I use hmonitor as well, which is very cool to know if it ever gets overheated.  The Seagate HD also has a cd that will do the partition and assignment of the drive letter if you don't like messing with disk management. Here is the manufactures site for this enclosure with a lot more detail about the device.
http://www.sunbeamtech.com/PRODUCTS/Airbox/Airbox-External-Enclosure.html
Edited by e06028 - 16 Nov 2009 at 12:54pm
  Quote e06028 Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 12:59pm
And yes after you assign the drive letter you can unplug it and then replug it in and it comes right up (hot swappable).
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 1:00pm
I like that.  Do you find it more reliable to use the eSata over the USB connection?  Or, does it really matter.
  Quote e06028 Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 1:13pm
I have to use the USB for the work PC but when I have it at home I use esata.
Either one is reliable, but the esata is just faster and allows me to keep the USB ports open for other things. There are not many enclosures that offer esata and the ones that do don't always include the esata cable, but this one does.
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 1:19pm
Thanks for all the info, e06028.  You've been very helpful.
  Quote e06028 Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 1:25pm
No problem. If you get one let me know how you like it.
  Quote B5GkarNarn Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 5:01pm
1) What tools do you need to install a HDD in an external enclosure?
2) Are there any printed instructions that come with the external enclosure that serve as a tutorial for installing the HDD inside it?
3) Are there any tests that I can run to ensure that I've assembled the HDD/external enclosure correctly?
  Quote e06028 Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 5:34pm
For the Sunbeam one I mentioned above all you need is a screwdriver which is included in the box when you get it, it also has the screws to mount it with.  It took me all of 10 minutes to put it together.  The test will be when you plug it in and it starts working right away.  Remember that you have to use disk management to assign a drive letter other than that it is the same as installing an internal drive only easier. Here is some more info.
And yes there are printed instructions with pictures that show you how to install it.
http://overclockershq.com/hardware-reviews/sunbeamtech-airbox-3.5-esata-usb-external-enclosure-review.html
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 6:19pm
@B5GkarNarn, as e06028 mentioned, the install of HDD is very easy, if you know hot to add a HDD to your system then you know how to add it here.
the one e06028 is talking about takes a 1TB HDD so you know it will fit that and everything under it.
@e06028, thanks a lot for the info, please let us know in 2 month or so what you think of it too.
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 7:00pm
Any recommendations on a good 1TB HDD?  Pricing?  I love the look of this enclosure and the blue lights just capture me.  It's a very handsome piece of hardware.
Edited by EdH63 - 16 Nov 2009 at 10:47pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 7:21pm
couldn't say, I always liked seagate, but I don't owe any 1TB so I can't say first hand.
DL13 View Drop Down
  Quote DL13 Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 7:43pm
Personally I prefer Western Digital as I had issues with Seagate a while back.  I just picked up a couple of WD10EADS (1TB Caviar Green) from Newegg for a NAS I built. http://www.newegg.com/Product/Product.aspx?Item=N82E16822136317  I didn't need the performance of the black for my NAS so price and power consumption were the main drivers.  Had just had a couple of weeks; no issues.
  Quote B5GkarNarn Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 10:49pm
Thank you very much, e06028!
I've never installed an internal HDD into a computer - I've only removed one from
my father's computer after the whole thing went kaput.  That's why I'm very cautious about this whole thing about assembling my own external hard drive.
What is disk management?
  Quote B5GkarNarn Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 10:52pm
I don't know how to install an internal HDD into a computer - I've only removed one from a computer that was no longer working.
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 10:58pm
Go into your Control Panel > Administrative Tools > Computer Management > Disk Management.  Here, you will see your HDs.  This is where you can partition your drives to a size you prefer, check the health of your drives and name your drives.
Edited by EdH63 - 16 Nov 2009 at 10:59pm
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 11:04pm
Installing internal HDs is the same as external HDs... plug n play.  The difference is the external HD will have it's own enclosure outside the PC case and you will sit it on top of your desk or a place of your choice.  DST's route is most likely cheaper than buying an enclosure.  However, I love the look of the Sunbeam and I'll be ordering that enclosure, a WD Caviar 1TB HDD and a couple of case fans tomorrow.
Edited by EdH63 - 16 Nov 2009 at 11:05pm
BriSleep View Drop Down
  Quote BriSleep Quote  Post ReplyReply bullet Posted: 17 Nov 2009 at 12:06am
Disk Management, it's Windows way of saying change you disk and partition letters, format your drives and put multiple partitions on your bigger drives. It's in the control panel/ administrative tools/ Computer Management/ Storage /Disk management. That's in Win7, If I remember, in XP you'd just start at Administrative tools, the rest, the same.
  Wise old indian say (BTW, that's me), go to Amazon .com get Windows (insert version here) Inside Out. Yes it's a Microsoft book but who better to tell you where to find everything??
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Nov 2009 at 12:14am
my route is no different, you buy an enclosure, like the sunbeam enclosure, and then drop what ever HDD you want in it.
as for connecting the HDD, its very simple, the enclosure will have a data cable and a power cable for you to connect to the HDD.
sata data cables:
sata power cables:
now regular hdd is a bit bigger but its the same connectors and wires and such.
Edited by DST4ME - 17 Nov 2009 at 12:21am
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 17 Nov 2009 at 12:20am
Hey DST, throw up a pic of the EVGA 680i SLI A-1 MOBO here and show me the extra sata ports available for me to plug into, please.  I would rather plug into sata then use USB with this external.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Nov 2009 at 12:27am
not sure what you mean, you got 6 sata ports right?
I see firewire and usb but I don't see esata for that mobo.
you can just get a esata pcie card.
Edited by DST4ME - 17 Nov 2009 at 12:27am
  Quote BriSleep Quote  Post ReplyReply bullet Posted: 17 Nov 2009 at 12:42am
Oh, I'm talking about the latest eVGA boards they got here on DS, like the one I'm getting. Eight external USB,  6 internal Sata, at least one of those is going to be free or like DST says get a pci board, that should give you 2 eSata and 2 internal Sata and that thing DST doesn't like, ummm Raid!Broken%20Heart
  Quote BriSleep Quote  Post ReplyReply bullet Posted: 17 Nov 2009 at 12:46am
Forgot, what's that really wide gray thing in the back? I think I have one of those around here somewhere. Hey did you guys read on, oh dang can't find what board but some kid just got a kick ass DS system and his wife wants him to put it in a cabinet! He want's to know how to cool it. Check out my answer.
  Quote BriSleep Quote  Post ReplyReply bullet Posted: 17 Nov 2009 at 12:48am
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 17 Nov 2009 at 12:48am
Yeah, I guess I was trying to ask if I had esata connections on my board too.  So, I'll need to get a esata pcie card also?  Is there a specific card you'd recommend over another?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Nov 2009 at 1:19am
not really, I'm not too familiar with those.
