Help with choosing right/best set up
Post Date: 2020-12-08
GeorgeLDN View Drop Down
  Quote GeorgeLDN Quote  Post ReplyReply bullet Topic: Help with choosing right/best set up
    Posted: 08 Dec 2020 at 7:31pm
[2-3 k ]
[just for gaming I have only ever play console PS4 and it Isit cutting it I wanna move on to pc gaming so highest frames possible and quick speed good gpu 3080 pref ]
[ shooting games ]
[high frames runs comfortable
[Please Type Here]
  Quote GeorgeLDN Quote  Post ReplyReply bullet Posted: 08 Dec 2020 at 7:33pm
Also can it be ship to London uk with a crate , I see a post DS reputed saying if you get in touch thay can cater to it ,it so hard finding the right pc as I only played Xbox PS4 plz can show one show me the right build 2-3 k willing to spend on rig
  Quote Cretae Quote  Post ReplyReply bullet Posted: 09 Dec 2020 at 3:48am
I decided to choose a Lynx case because it will stand up to shipping the best IMO. Here is the build:
   3627335       $2374   To see this, copy and paste the number into the window that opens when you click the "Load Config" in the upper right of the main page.
There are no significant compromises here. It will play great on a 2K (1440p) monitor resolution or the lesser 1080p. The budget allows plenty leftover for whatever DS recommends for shipping to the UK.
  Quote GeorgeLDN Quote  Post ReplyReply bullet Posted: 09 Dec 2020 at 5:21am
Is the computer beast for competitive?
  Quote GeorgeLDN Quote  Post ReplyReply bullet Posted: 09 Dec 2020 at 5:24am
Thanks for the reply , you saying the 3070 over 80 and 90
  Quote GeorgeLDN Quote  Post ReplyReply bullet Posted: 09 Dec 2020 at 5:33am
Amd over intel?
grasoline View Drop Down
  Quote grasoline Quote  Post ReplyReply bullet Posted: 09 Dec 2020 at 8:20am
If you're playing competitive shooters, you'll be playing on a 1080p monitor. If you're playing on a 1080p monitor than the 3070 is more horsepower than you'll ever need. The 3070 is borderline overkill for a 1080p.
Ryzen 2nd gen competes and sometimes supersedes intel, (3rd gen outright defeats intel) - namely when we're talking gaming. Cretae's rig is great for your use case. If you want you could go for the 5600x (although 6 cores, the newest gen is pretty insane for gaming) - or switch to intel - that's fine. It doesn't really matter. Just make sure to spend at least 300 on the CPU. Anything you do in this price range will make your PS4 look like a toaster. But be sure to shop around for an excellent 1080p monitor. They are affordable. 1440p is more money, for a prettier picture but less fps.
Things to look for in a monitor: Response time (1-2ms) Hertz (at least 144hz but go higher if you can), and IPS.
Edited by grasoline - 09 Dec 2020 at 8:21am
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Posted: 09 Dec 2020 at 7:49pm
3070 for 1080p should be more than enough! I have a Gigabyte 2070 super OC on a 1080p@144hz and I play COD BOCW max settings getting 170+ frames. When I play at competitive settings it borderlines at 190 or so
I7 13700KF 5.4hz
ASUS Prime z790 MoBo
ASUS Dual 4070
32g ram@5200
850 Gold PSU
1TB SSD 2TB SSD
27" ASUS Monitor 144hz
Razer Ornata Chroma Keyboard
Razer Basilisk V2 Mouse
Nari Ultimate Headset
  Quote Cretae Quote  Post ReplyReply bullet Posted: 10 Dec 2020 at 3:54am
IPS refers to the type of panel for best colors/viewing angle. If you get the 3070, you will also want a G-sync compatible monitor.
The selection of the 3070 is as others said: best money can buy for 1080p and competitive fps, and capable of good results at 1440p. Well within the budget. Great card.
