Help with Config ~$2800
Post Date: 2011-10-28
Avelict View Drop Down
  Quote Avelict Quote  Post ReplyReply bullet Topic: Help with Config ~$2800
    Posted: 28 Oct 2011 at 12:23pm
Hell everyone,
   So I'm pretty new to computers, not very familiar with hardware, but i am needing a new rig regardless, my old setup is toast. And through some serious penny-pinching i have a 2500$ budget on the computer, and needing to be pretty strict regarding that. Aside to that i have 300$ set aside for a monitor.
Expectations: I'm just looking for a good setup that will run high/max settings for online games (RIFT/GW2) and best visual settings as i can for higher taxing games like Elder Scrolls V to be released soon.
Special Needs: I've been reading a lot on SSD's andI like the thought on them, not sure how much the run in terms of pricing but it'd be cool to have I think. Also with a 2500 budget on the PC, is there an advantage of running two slightly lower GPU's with SLI or one awesome GPU???
Thank you for any help in advance!
  Quote FrankW Quote  Post ReplyReply bullet Posted: 28 Oct 2011 at 1:09pm
Hi Avelict, welcome to the forum.
You need to select your monitor first. For $300 you can get an IPS in the 23/24 inch range with 1900x1080/1200 resolution. For that budget level and resolution your very best computer choice is the ODE-3.
See the ODE-3 here.
ODE-3
Edited by FrankW - 28 Oct 2011 at 1:11pm
sneaky George W View Drop Down
  Quote sneaky George W Quote  Post ReplyReply bullet Posted: 28 Oct 2011 at 1:29pm
Hey Avelict,
here's my build for you: 610267
Specs:
Motherboard: ASUS P8P67 (Intel P67 Chipset) (New B3 Revision) (Does Not Support SLI)
Hard Drive Set 1: Operating System: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Tech) (EVGA Edition)
it costs $2516 plus shipping, which would be ~$65, if thats too much then you can cut one of the 570's and add it later. it doesnt have a SSD, but those dont really affect gameplay a whole lot, if you have your heart set on a SSD, we recommend the intel 320 series 120gb. for best air flow its recommended that you ask them to add an additional 200mm fan on the top of the case, it will cost another ~$20.
also you could consider an ODE 3, the build above has better upgradeability and thus longevity, but if thats not your cup of tea then id consider the ODE 3.
to answer your SLI question, the 570's or 580's are the best cards right now. which you want depends on your resolution, at 1900x1080 youre not going to see a difference between a 570 and a 580. at higher res 580's are better, and your going to want the higher Gb versions (3gb 580's, 2.5gb 570's). if you have one of those cards your going to be pretty happy, if you have two youre going to blow through just about anything.
with this build im assuming that youre going to be gaming on a single monitor at 1900x1080.
I personaly have sli 570's (1.5gb) at that res and love it.
good luck! your going to love Digital Storm!
Boss Man View Drop Down
  Quote Boss Man Quote  Post ReplyReply bullet Posted: 28 Oct 2011 at 2:24pm
Sneaky, I think you forgot to change the motherboard selection to one that supports SLI, like the Deluxe or Sabertooth.
Also, that build lacks a Blu-ray drive in addition to the SSD as compared to the ODE Level 3. Just sayin'.
I don't know sh*t about computers. Not. sh*t.
  Quote Boss Man Quote  Post ReplyReply bullet Posted: 28 Oct 2011 at 2:42pm
To better illustrate the cost savings of the ODE, I altered Sneaky's configuration to feature identical components to those found in the ODE Level 3, and the resulting price, as can be seen below, is much higher.
610294
Whether you would prefer the cost savings of the ODE Level 3 or the better PSU (among ever so slightly better components featured throughout the rest of the build) of the custom configuration is up to you. It really depends on how much you're willing to spend when it comes down to it.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Oct 2011 at 10:11pm
For that price range ode 3 is what you want, custom config will give you better parts like the psu/cpu cooler, case, mobo, etc but it will be out of your price range.
