Help with Config for Business Computer
Post Date: 2011-04-16
rosevilleca View Drop Down
  Quote rosevilleca Quote  Post ReplyReply bullet Topic: Help with Config for Business Computer
    Posted: 16 Apr 2011 at 4:00pm
Hello,
I am looking for suggestions on either a new configuration or suggestions for modifications to the one below.  I am looking for a computer that is quiet, small footprint, and is able to accomodate 20 simultaneous windows open in a internet browser, with Adobe Acrobat and Excel and Word useage.
I never want to have to wait on my computer, but I want the computer to be always waiting for me to make keyboard inputs.  I don't play any games, but I want a graphics card that is at least able to play modestly, a few games here and there, maybe WOW on a 30" screen.  I will hardly ever be playing games.
Hope you will make some suggestions for a configuration for a computer!
Total Price with Instant Savings: $2,461.00
Direct Load URL: http://www.digitalstormonline.com/comploadsaved.asp?id=523497
Chassis Model: Special Deal Hot Seller - Black OPS Enix Edition
Motherboard: ASUS P8P67-M PRO (Intel P67 Chipset) (New & Improved B3 Revision Without SATA 3G Issue)
Expansion Bay: External USB Digital Media Card Reader
Hard Drive Set 1: Operating System: 1x (250GB Solid State (By: Intel) (Model: 510 Series SSDSC2MH250A2K5) (Extreme Performance)
Optical Drive 1: Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Slim Slot Loading Edition)
Video Card: 1x NVIDIA GeForce GTX 550 Ti 1GB (Includes PhysX Technology)
Extreme Cooling: Standard Factory Heat-sink and Fan (Not Recommended for CPU Overclocking)
Boost Processor: FREE: Overclock the processor between 3.6GHz to 3.9GHz
Recovery Tools: Windows Recovery
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 16 Apr 2011 at 7:14pm
- I must have over 20 tabs or more open in Firefox on a daily basis, and I rarely will go over 3GB usage....ehehe
- That's going to one BLAZING fast office computer...just fyi...kind of overkill if you ask me if it's just for office haha.
- 250GB SSD? My recommendation is a 120GB Intel 320 series SSD, controller's had a better legacy and reputation, and it should be more than enough. Having a bigger capacity SSD is pointless if you really don't need to put that much on it, I'm not sure what'll be good to load up on that much space.
- Overclocking on stock coolers isn't recommended in my opinion. IMHO, a H70 is probably all you need, and it accommodates that case's form factor well. Larger coolers will fit, but I dunno, it just looks odd and I think since smaller cases like that are more prone to shifting, it's not too good of a choice.
Edited by ablahblah - 16 Apr 2011 at 7:16pm
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Apr 2011 at 2:06am
I have over 50 taps open at any given time, but which browser you use makes a difference also, chrome for example is the worst, and uses crazy amount of ram.
Here you go Ticket# 523778 --- $1991 (To see this build click here)
Motherboard: ASUS P8P67 (Intel P67 Chipset) (New B3 Revision) (Does Not Support SLI)
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Intel) (Model: 320 Series SSDSA2CW120G3K5)
Video Card: 1x NVIDIA GeForce GTX 560 Ti 1GB (Includes PhysX Technology)
Boost Processor: Stage 1: Overclock the processor between 4.0GHz to 4.5GHz (Cooling Upgrade Recommended)
90% of your noise will come from the gpu's fan while under load.
your HDD setup should be:
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 01 Apr 2014 at 12:14pm
Originally posted by JohnVick
I think you should also take into account the degrading speed of the system caused by the junk files created by the system and the web browser which results the viruses to come in i am using krojam cleaner in my system to clean that mess up for me
This was posted in 2011.....
Eggy View Drop Down
  Quote Eggy Quote  Post ReplyReply bullet Posted: 01 Apr 2014 at 12:34pm
Sweet thread resurrection. How bout that 1GB GPU!
Nav View Drop Down
  Quote Nav Quote  Post ReplyReply bullet Posted: 01 Apr 2014 at 12:59pm
Pretty sure the JohnVick account was a bot, i've seen that "krojam" posted here before by another account with 1 post.
Meller View Drop Down
  Quote Meller Quote  Post ReplyReply bullet Posted: 01 Apr 2014 at 3:48pm
I missed the bot! -_- Not cool... I always miss all the fun.
Custom PC
Ryzen 9 5950X
Gigabyte X570 Aorus Xtreme
128GB DDR4 3600mhz
Samsung 980 Pro 512GB m.2
Samsung 960 PRO 2TB m.2 x2
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 01 Apr 2014 at 3:51pm
Poor Meller!!! Lol
