Help with config on pc (help I'm new)
Post Date: 2020-12-27
purplecherries View Drop Down
  Quote purplecherries Quote  Post ReplyReply bullet Topic: Help with config on pc (help I'm new)
    Posted: 27 Dec 2020 at 8:40pm
Hi, this would be my first pc and I wanted to get one that would last at least a few years.I used a previous post as a guide to make this PC, but I changed a few things. Since I know very little I was hoping someone with more experience could see if anything looks wrong or needs to be changed. Thanks!!
2500-2700
Gaming/Streaming
none
Configuration Code:3680822
Processor: Intel Core i7-10700K (5.1 GHz Turbo) (16-Thread) (8-Core) 3.8 GHz
Motherboard: ASUS TUF GAMING Z490-PLUS / MSI MPG Z490 GAMING EDGE (Intel Z490) (Up to 3x PCI-E) (No SLI) <br><strong></strong>
System Memory: 32GB DDR4 3000MHz G.Skill TridentZ (RGB Light Bar) <br><strong></strong>
Power Supply: 850W Digital Storm Performance Series (Modular) (80 Plus Gold) <br><strong></strong>
Optical Drive: - No Thanks
Storage Set 1: 1x SSD M.2 (500GB Seagate FireCuda 520) (NVM Express) (Gen4 PCIe) <br><strong></strong>
Storage Set 2: 1x SSD (1TB Samsung 860 EVO) <br><strong></strong>
Graphics Card(s): 1x Radeon RX 5700 XT 8GB (VR Ready) <br><strong></strong>
Extreme Cooling: H20: Stage 1: Digital Storm Vortex Liquid CPU Cooler (Single Fan) (Fully Sealed + No Maintenance)
Cable Management: Exotic Cable Management - Black - (Cable Combs with Custom Color Sleeved Extension Cables) <br><strong></strong>
Airflow Control: - No Thanks
Mouse Pad: - No Thanks
Display: MSI 24 inch Optix G241 (144Hz Refresh) (1ms Response) (1920x1080) <br><strong></strong>
Keyboard: Digital Storm MasterKeys Lite Bundle (RGB) Keyboard & Mouse <br><strong></strong>
Branded Gear: - No Thanks
  Quote Cretae Quote  Post ReplyReply bullet Posted: 28 Dec 2020 at 4:26am
It's a solid budget build. I have read that the 3060 Ti is about 20% stronger than the 5700 XT for just another $69, but either card is stronger than you need for 1080p gaming. 32GB of RAM is not needed, but I suggest you get the better dual fan CPU cooler.
Here is an alternate build with a little less raw CPU speed, but on the PCIe Generation 4 platform from AMD. It allows for the RTX3060 Ti and still saves a bit over $200:
          3681496       $2351 with discount.
The newer platform will improve performance all-around. It's not a game-changer, but it will be better for any future enhancements. It would also allow for an upgrade on the same motherboard to a 5000 series CPU in the future. I don't think you would need that for gaming for the lifetime of this build, but the option is there.
  Quote purplecherries Quote  Post ReplyReply bullet Posted: 28 Dec 2020 at 6:34pm
thank you so much!!!
  Quote Cretae Quote  Post ReplyReply bullet Posted: 29 Dec 2020 at 3:36am
A pleasure.
