Help with config
Post Date: 2011-03-27
WaW2001 View Drop Down
  Quote WaW2001 Quote  Post ReplyReply bullet Topic: Help with config
    Posted: 27 Mar 2011 at 3:33pm
I am trying to get a build that would allow me to play EverQuest 2 at the max settings. My budget is around $2,500. My res is 1920 x 1080. This is what I have come up with so far.
 http://www.digitalstormonline.com/comploadsaved.asp?id=509289
Any advice would be greatly appreciated.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Mar 2011 at 6:04pm
correct me if I'm wrong but isn't a 570 overkill for eq2?
I don't play but from what I have seen the old cards play it well at 1600 x 1200, so I'm assuming that 570 is like almost twice as much as it needs, but if you know better let me know:
Here you go Ticket# 509414 --- $1977 (To see this build click here)
Motherboard: ASUS P8P67 (Intel P67 Chipset) (New & Improved B3 Revision Without SATA 3G Issue)
Hard Drive Set 1: Operating System: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition WD1002FAEX)
Boost Processor: Stage 1: Overclock the processor between 4.0GHz to 4.5GHz (Cooling Upgrade Recommended)
Ask DS specifically for this fan to be added to the side, so you endup with 3 x 200mm fans:
haf 200mm non led fan
btw my cpu is more powerful then the old 950, and unless I'm mistaken there is no way you gonna tell the difference between 580 and 570 in eq2 at 1900 x 1200.
