Help with Configuration
Post Date: 2008-09-18
Tyzardx_73 View Drop Down
  Quote Tyzardx_73 Quote  Post ReplyReply bullet Topic: Help with Configuration
    Posted: 18 Sep 2008 at 7:31pm
hello, I'm Farly new to computers, and i am looking for something that can play the latest games in high quality without many problems, this is my config so far, looking to spend around $3,500, maybe a little more, please input anything you think would be helpful, thanks a lot!
Total Price with Instant Savings: $3,519.00
System Memory: 4GB DDR3 1600MHz OCZ Platinum Edition
Card Reader: - No Thanks
Hard Drive 2: - No Thanks
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Optical Drive 2: DVD-ROM/CD-ROM (DVD Reader 16x / CD Reader 40x)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 280 1GB) (Includes PhysX Technology)
TV Tuner: - No Thanks
Extreme Cooling: Air Cooled Stage 3 WindTunnel (Copper Heatpipe Heatsink & Additional Case Fans)
Internal Lighting: Blizzard Internal Lighting (Red Edition) (Cold Cathode Tubes)
Modifications: - No Thanks
Protection: - No Thanks
LCD Display: - No Thanks
brandon92591 View Drop Down
  Quote brandon92591 Quote  Post ReplyReply bullet Posted: 18 Sep 2008 at 7:39pm
Edited by brandon92591 - 20 Aug 2018 at 1:35pm
  Quote Tyzardx_73 Quote  Post ReplyReply bullet Posted: 18 Sep 2008 at 7:44pm
yeah, i was thinking about that, but i wasn't sure if i really needed it or not.
Jail Bird View Drop Down
  Quote Jail Bird Quote  Post ReplyReply bullet Posted: 18 Sep 2008 at 9:50pm
How reliable is liquid cooling as far as leaks ?? Especially as the system ages I wonder ?
lighn'ing fps
  Quote Jail Bird Quote  Post ReplyReply bullet Posted: 18 Sep 2008 at 10:22pm
Thanks for the info .. do you know of any problems with water cooling as far as leakage ?
lighn'ing fps
  Quote Tyzardx_73 Quote  Post ReplyReply bullet Posted: 18 Sep 2008 at 10:30pm
thanks for the advice everyone, it has helped quite a bit, harleyman, i have taken to consideration what you have said an will most likely add a smaller HDD for just apps and the OS. thanks again everyone.
  Quote Tyzardx_73 Quote  Post ReplyReply bullet Posted: 18 Sep 2008 at 10:56pm
i have a question about how that works thought if you don't mind, i mean, how do i go about running games when i'm running the OS off another HDD? sorry for the stupid question but, i'm new to all this ha ha.
  Quote Tyzardx_73 Quote  Post ReplyReply bullet Posted: 18 Sep 2008 at 11:31pm
ahh, okay, thank you so much for explaining that, helps a bunch. i'm deff gonna spend a little extra to go for that second hard drive then.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Sep 2008 at 12:54am
when you install the game, you will be asked whhere to install, point to your second drive and the game will install itself there
widdlecat View Drop Down
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 19 Sep 2008 at 1:40am
That mobo also has great onboard sound..It might utalize about 2-3% of your total CPU to run it.......You have plenty of CPU to drop the card if needed for perhaps the Q9650.....
At that price point, I wouldn't consider the mobo's onboard sound to be adequate. The Razer Baraccuda is cheap for such a system and will sound significantly better. Then again, I listen to music on my pc as well as play games.
