Help with DSO OC
Post Date: 2009-07-04
Jennings386 View Drop Down
  Quote Jennings386 Quote  Post ReplyReply bullet Topic: Help with DSO OC
    Posted: 04 Jul 2009 at 9:03pm
So, my computer just arrived and it does not seem that the OC that was done on my system is in place.  I mentioned that my 920 was only logging 2.7ghz according to CPUz.  I was told by some forum folks that I had SpeedStep enabled and that my CPU speed would ramp up as needed.
This got me curious about what was going on so I looked into speedstep online and ended up going into the BIOS on my last startup.  I didn't change anything, but I did notice that Speedstep was disabled and that hypermode was enabled.  I looked the Frequency section and found that all were set at the default or stock settings.  I am assuming that this means that my system is not currently OC'd.
Would hypermode account for my speed over the 2.66ghz stock 920?  And if there was an OC performed by DSO, how would I go about re-instating it?
  Quote Jennings386 Quote  Post ReplyReply bullet Posted: 04 Jul 2009 at 9:05pm
On a side note.  I am satisfied with the computer as it is a major upgrade over my 10 yr old P4 2.33.  I only wish that WoW was better at using the newer tech, because my gameplay has not improved significantly.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 04 Jul 2009 at 9:39pm
look in your bios there should be a saved profile, if there is one, load it, it has your OC settings, if not check your notebook and see if your settings are listed in there, if not, wait till Monday and give them a call, they have your settings saved
for whatever reason, your bios reverted to default.
Edited by DST4ME - 04 Jul 2009 at 9:40pm
  Quote Jennings386 Quote  Post ReplyReply bullet Posted: 04 Jul 2009 at 9:50pm
Thanks for the info.  I saw the saved profiles the first time through, but did not want to change anything without more information.
There are 8 saved profiles.  Would you think that all 8 are unique or would the listing be a standard number of save slots?
  Quote Jennings386 Quote  Post ReplyReply bullet Posted: 04 Jul 2009 at 9:59pm
I think I have it figured out.  Thank you DST4ME, you are a great service to these forums.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 04 Jul 2009 at 9:59pm
My pleasure, so you got the oc back?
Edited by DST4ME - 04 Jul 2009 at 10:00pm
  Quote Jennings386 Quote  Post ReplyReply bullet Posted: 04 Jul 2009 at 10:02pm
It appears so, but I have to say I'm a bit worried about stability and temps.  I would have been much more comfortable with the jump it it came already applied as tested.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 04 Jul 2009 at 10:54pm
the saved profile was tested, for whatever reason when you used your PC the bios reverted back to default.
put your PC under load and run HWMonitor and see what your max temps are
  Quote Jennings386 Quote  Post ReplyReply bullet Posted: 04 Jul 2009 at 11:39pm
I just ran 10 min of Prime95 and got a max temp of 72C.  That seems pretty good to me even though it wasn't a very long test.  Thanks again for the help.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Jul 2009 at 12:27am
NP, my pleasure, just let HWMonitor run in the background if you are worried, and every now and then check your temps, as long as your temps don't go over 80 - 85c during your use (gaming, work, etc) you got nothing to worry about
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 05 Jul 2009 at 1:01am
remember to add about 4C to WHM temps. to get the real temps. Cry
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Jul 2009 at 1:06am
how come? realtemp shows the same temps, its fanspeed that shows the wrong temps.
Edited by DST4ME - 05 Jul 2009 at 1:18am
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 05 Jul 2009 at 9:10am
Yesterday My wife and I went for the WR on Wprime 1024m, lol I blame her for the mis-calc..so now we are 2nd. lol. Any way I was using HWM to keep an eye on the V reg temp, they use to be 85C and were causing stability problems. I still had real temp open and noticed the temp differences between the two programs. So I ran a quick test again just to make sure.  Here it is.
Edited by justin.kerr - 05 Jul 2009 at 9:14am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Jul 2009 at 3:13pm
is that the latest version of hw? why is everything always wierd on your pc?
here is one user's temps:
lol I will look around and post other's pics when I find them.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 05 Jul 2009 at 7:19pm
newest versions of both programs, they get further apart as time goes on. lol
Here is just after a couple hours..
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Jul 2009 at 9:00pm
on my machines they are the same/very close (1c) but I don't' have an i7, all the other i7-s I have seen here are the same/very close (1c), I ask others to load them both and lets see what we get.
but if you look at your max temps they are almost exactly the same, meaning that no matter what max temps are the same, and max temps are what we worry about, now which one of the two is right we don't' know, but if the max temps are matching, they both good enough for me.
but
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 05 Jul 2009 at 9:55pm
max temp is 3-5 lower with hwm. hence why i said 4c.. lol
It would be awesome if HWM was correct, running 4.5 Ghz with HT on, and staying in the 50's. If I just lower my V core 2 more notches. lol That would be considered "decent". Embarrassed
Edited by justin.kerr - 05 Jul 2009 at 9:59pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Jul 2009 at 10:40pm
not sure why your temps are 4c different but I have not seen that any place else, as I said I will ask other members to run it also and lets see what everybody gets, but like I said we don't know which one is actually reporting the correct temp.
  Quote Jennings386 Quote  Post ReplyReply bullet Posted: 05 Jul 2009 at 10:52pm
I noticed this too, RealTemp is running about 4C higher on each core than HWMonitor
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Jul 2009 at 11:37pm
well I guess realtemp is using a higher tjmax settings, we don't really know what the temps are, some say realtemp is the more accurate but at the end of the day its a guess, but I guess its is better to read the hotter one just to be on the safe side.
for me unless the temp is around 80 - 85c I'm not gonna care about 5c difference for normal/gaming use.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Jul 2009 at 12:21am
OK so far I got justin and Jennings386 showing 4c higher with realtemp and I got william2 and Elmpe showing 1c difference.
I will keep searching, lets see if we have a winer out of 10 or 20, LOL I'm sure by the time we figure it out the newer versions will be out and it will not matter, last year around this time realtemp was the one showing the lowest number
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 06 Jul 2009 at 12:04pm
That is an old realtemp app. That guys V regs are HOT!!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Jul 2009 at 12:52pm
justin according to tpu 3.0 is the latest version, you must be referring to the beta version, beta is not final, I would take the final release over the beta any day, till the beta turns into final release.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 06 Jul 2009 at 1:11pm
haha I see, I am using release candidate #10.. Smile ATM
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Jul 2009 at 1:18pm
RC yes, this one has been having lot of RCs, but it is over due for a final
  Quote Alex Quote  Post ReplyReply bullet Posted: 06 Jul 2009 at 1:50pm
I'm glad you got it all worked out. Your temperatures are perfectly in-line for an overclocked system.
If you need any other help, feel free to give us a call or send us a message using our message system.
And a thank you to DST4ME for the help!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Jul 2009 at 1:52pm
My pleasure Alex
