Help with fans
Post Date: 2013-12-02
RobZGames View Drop Down
  Quote RobZGames Quote  Post ReplyReply bullet Topic: Help with fans
    Posted: 02 Dec 2013 at 8:30pm
I am looking to buy a computer in a week for the holidays. i wanted to know if the (Standard Factory Chassis Fans) come with a controller type thing. to make it increase or decrease speed?!
  Quote RobZGames Quote  Post ReplyReply bullet Posted: 02 Dec 2013 at 8:38pm
EDIT: i see there is a main fan for (extreme cooling) does all the fans have a controller
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 03 Dec 2013 at 5:02am
Depends what system you're looking at. Most fans can be software controlled in Bios or 3rd party programs. For hardware controlled fans, the ODE 600t case does have a front fan control for case fans. It only adjusts by about 25%,but does work. Otherwise a separate fan controller needs to be installed.
  Quote RobZGames Quote  Post ReplyReply bullet Posted: 03 Dec 2013 at 12:00pm
Im looking at the Marauder with the default fans on lvl 1. can you tell me about them
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 03 Dec 2013 at 12:31pm
The Marauder is built around the Corsair C70 case in case you want to Google it to check it out. I believe it has two front and 1 rear 120mm fans. If they're plugged into the motherboard, and I think they are, then AI Suite3 and Fan Xpert are programs with that mobo to adjust fans. The Hyper212 cooler can also be but should be left alone for proper cooling. Even the case fans shouldn't be turned down too much or cooling drops. There is no mechanical fan control knob or slider for fans. All software, which is easy to use once you get used to it.
Hope this helps.
