Help with future buildPost Date: 2012-02-01 |
| Author | |
storm0545
Joined: 28 Jan 2012 Online Status: Offline Posts: 84 |
Topic: Help with future buildPosted: 01 Feb 2012 at 10:12am |
Hello everybody storm here and I was wondering if I could ask you guys to chime in with your opinions on the build I'm posting. My budget is pretty forgiving so I can afford to drop an upwards of about 5k+ if needed to make this thing perfect. I plan on using this desktop for gaming at the highest quality possible. As I really don't know all the ins and outs when it comes to PCs just yet I will most likely need your help but I think I'll be able to understand what you guys post. The planned resolution I'll most likely be gaming at is 1920x1080 with some 3d thrown in there here and there.
The ticket number for the build I've been considering is 650431 Once again I thank you guys immensely in advance. |
AndydViking
Joined: 10 Sep 2009 Online Status: Offline Posts: 733 |
Posted: 01 Feb 2012 at 1:23pm |
Here's the specs of the config storm0545 posted @ $5,595.00:
Chassis Model: Special Deal Hot Seller - Black OPS HailStorm Edition Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 3930K 3.2GHz (Unlocked CPU for Extreme Overclocking) (Six-Core) Motherboard: ASUS Rampage IV Extreme X79 (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s) System Memory: 8GB DDR3 2000MHz GTX-8 Digital Storm Certified Performance Series (Highly Recommended) Power Supply: 1200W Corsair Pro Gold Series (CMPSU-1200AX) (Dual/Triple/Quad SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (160GB Solid State (By: Intel) (Model: 320 Series) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 2x SLI Dual (NVIDIA GeForce GTX 570 2.5GB (PhysX) (EVGA 025-P3-1579-BR) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Dual SLI/CrossFire Video Cards H20 Tube Color:Blue Tubing with High-Performance Fluid (UV Lighting Reactive) Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (UV) (Creates Glowing Effect for H20 Tubes) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro or Deluxe Series Motherboard) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: Memory Fan Kit Only (Does not include memory overclocking service) Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Game: - No Thanks Display: NVIDIA 3D Vision Kit (Asus 23 inch 120Hz VG236H + NVIDIA 3D Glasses) Surge Shield: - No Thanks Speakers: Corsair 2.1 System (Includes Subwoofer) (CA-SP212NA) Keyboard: Razer Arctosa Gaming Keyboard (USB) (RZ03-00260800-R3U1) Mouse: Razer Deathadder (Infrared 3500 dpi) (Gaming Mouse) (USB Wired) External Storage: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Extra Large) Priority Build: - No Thanks, Ship Within 5-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 4 Year Limited Warranty Edited by AndydViking - 01 Feb 2012 at 1:28pm |
AndydViking
Posted: 01 Feb 2012 at 1:25pm |
What kind of games do you play? For the latest FPS games you might need another GTX 570 there.
*If I were you and you really wanted to game at 120hz I'd drop the cooling on the cards (unless you really want to overclock them). And I'd add anther card. *Or you could get a Dell 24" IPS @ 60hz and forget the other card. *Liquid cooling on the GPU's/graphics cards makes it harder to upgrade the cards when their not powerful enough anymore. *Of course, if you don't liquid cool the cards you might wanna go HAFX because those cards will want better cooling. Also, have you used the deathadder before? If you are a high sensitivity player I don't recommend that mouse because its not comfortable to pick up a lot. But that's just IMHO. I'd probably get my kb/mouse and monitor somewhere else. Edited by AndydViking - 01 Feb 2012 at 1:41pm |
storm0545
Posted: 01 Feb 2012 at 10:07pm |
I have a very old 1800 dpi deathadder and I love it, I just felt like getting a newer version of it so I could give the old one to a relative. Game wise I play everything under the sun cod, mass effect, metro 2033, the elder scrolls and fallout games bf3 RO2 world of tanks eh the list goes on.
As per your suggestions I'll switch cases I love the way the other case looks but at that point instead of 3 570's should I just go 2 580's? Also while browsing other posts with that case I have to request special fans to be put in instead of the stock ones right? And if anything like you suggested I'll hit up newegg for the keyboard/mouse, as for the screen I really do want the 3d bundle I've seen 3d before with other games and it looks awesome. |
AndydViking
Posted: 02 Feb 2012 at 12:12pm |
@storm0545 I am surprised others haven't been along.
*Just so you know you don't have to liquid cool your CPU either. You could use the Noctua and be just fine on air. (I'm not trying to steer you away from liquid on the CPU just letting you know that, true liquid cooling will be awesome). *I agree about the HAFX but it is a great case and the best bang for your buck if your air cooling components. *I'd go with 3 GTX 570's as your going for 120 fps with the 120hz monitor. *You don't have to add that fan but it's nice to get the bonus airflow and have it done from the get go. And yes just special request it. **I'd wait for others to chime in. I am OK at this but their are others better than me on this forum. I think most will tell you much the same that I did. Edited by AndydViking - 02 Feb 2012 at 12:24pm |
storm0545
Posted: 02 Feb 2012 at 9:11pm |
Your responses so far have been extremely helpful and based off your last reply I'm assuming the liquid cooling on the cards and cpu is not needed. If I switch to the HAFX w/special fans w/ Noctua air cooling I'm assuming (once again :)) the cooling performance is equal to what I would see if my system was water blocked? and hmm 3 570's allright no problem also my next question probably slightly dumb is, when i go to install drivers for all 3 cards is it just 1 single install like usual or 1 for each card?
AndydViking
Posted: 02 Feb 2012 at 9:56pm |
*liquid cooling is not needed on anything. It is more of a 'want' or luxury. Slightly less so with the processor you selected as they run a bit hotter but still definitely not needed.
*air and the H2O cooling you selected isn't going to be equal in the temperatures they can produce. The H2O will outperform the Noctua. However, the Noctua should be able to get you to your maximum safe overclock. In other words…liquid cooling is better but the Noctua will be good enough performance wise and be pretty quiet. *when you install drivers you will only be installing them once as all the video cards will be the same. |
AndydViking
Posted: 03 Feb 2012 at 2:39am |
If I were you I'd do something like this:
Ticket #: 651067 Chassis Model: Special Deal Hot Seller - Cooler Master 942 HAF X Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 3930K 3.2GHz (Unlocked CPU for Extreme Overclocking) (Six-Core) Motherboard: ASUS P9X79 DELUXE (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 1200W Corsair Pro Gold Series (CMPSU-1200AX) (Dual/Triple/Quad SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (160GB Solid State (By: Intel) (Model: 320 Series) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 3x SLI Triple (NVIDIA GeForce GTX 570 2.5GB (Includes PhysX) (EVGA 025-P3-1579-BR) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 2: Noctua NH-D14 SE2011 Extreme Performance H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: - No Thanks Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro or Deluxe Series Motherboard) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Game: - No Thanks Display: NVIDIA 3D Vision Kit (Asus 23 inch 120Hz VG236H + NVIDIA 3D Glasses) Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 5-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 4 Year Limited Warranty And as DST4ME always says: Ask DS specifically for this fan to be added to the top, so you endup with 4 x 200mm fans: haf 200mm non led fan Ask for vcore lower then 1.4 for your oc. *I changed the motherboard because it's all you need but go extreme if you wanna *you might consider the rgular GTX 570's to save money but I'm thinking the 2.5's will come in handy for Metro 2033. *I left your warrenty the way you had it *I left the monitor in there too *if you go with this build don't forget to add lighting if you want that *Get your free t-shirt ******anyone else wanna look over this and comment? To make sure I didn't make an error?!?
Edited by AndydViking - 03 Feb 2012 at 3:03am |
Posted: 03 Feb 2012 at 4:18am |
Hi storm 0545... The rig AndyViking put together is , IMHO, a dynamite system.
I personally would up the warranty to at least 5 year labor/ 3 year parts but that's just my thing. The reason I didn't jump in earlier is because I know very little about liquid cooling, your initial liking, and didn't want to give bad info. Other than a system running maxed out 24/7, or noise or just a personal want, I don't know why a stage 4 plus would be needed. Others will surely tell me, which would be great. Best of Luck
storm0545
Posted: 03 Feb 2012 at 5:51am |
Thanks everyone especially to Andy for fixing my rig. I'll be holding onto this config for a while before I can buy it since I'm waiting for the money to come in :) but it shall be worth it. And bprat22 I'll make sure to up the warranty because for some reason in my household Murphy's law tends to flare up all the time :( But yea I can't wait to be blown away by how a desktop shall be compared to my old asus g73 :)
Posted: 03 Feb 2012 at 6:41am |
New nVidia gpu's are coming in April, supposedly, so that might change things for you if you wait until then..
And to answer your next question Thumbs up to warranty upgrade...it's just easier to have a single source, DS, that tells you what's wrong and sends the part to ya. Good Luck.
Edited by bprat22 - 03 Feb 2012 at 6:41am |
AndydViking
Posted: 03 Feb 2012 at 7:07am |
+1
