help with liquid cooling gpu
Post Date: 2009-06-17
socom360 View Drop Down
  Quote socom360 Quote  Post ReplyReply bullet Topic: help with liquid cooling gpu
    Posted: 17 Jun 2009 at 6:36pm
In my pc i have a sapphire HD 4870 1gb and at times it can run kinda hot.  I was thinkin of liquid cooling it but have no experience with liquid cooling.  Any idea for cooling blocks etc.  I have looked at a few but i dont know if they are compatible with mine. I don't really want to spent more than $200 if possible(don't really know how much liquid cooling costs).  If any of you could help me out i would appreciate it.
Here's a link to some info on my gpu
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102801
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Jun 2009 at 7:39pm
you gonna need to spend more then $200, the rad is gonna run you about $60 bucks, the pump is gonna cost about $80 bucks, the water block is gonna cost you about $130, thats not counting, shipping, hose, etc etc.
not worth it if you ask me, what is the temps under load anyways? is the fan set to run at 100% ?
Kaleliar View Drop Down
  Quote Kaleliar Quote  Post ReplyReply bullet Posted: 18 Jun 2009 at 11:33am
Most temp issues ive seen in forums (other places then DS also) they have everything set to auto.
Set it to manual in the ATI controller, (in the Overdrive part) then set fan speed at 100%. Also remember that it will clock up automatically when under load if you set it to do that.  If I set mine to auto it waits till about 75C before it starts to really blow the heat out.
So like DST said, check to see the temps when you run it at 100%. Even when I have WoW and WAR up at the same time I don't see much over 60C, 80C is the worry zone for me. (Tho I have an room that is AC'd to 50F so that makes a huge temp difference).
Not to mention that if you were going to LC the GPU you need to know how to take off the Heatsink.
Edited by Kaleliar - 18 Jun 2009 at 11:39am
Rock: "We're sub-standard DPS. Nerf Paper, Scissors are fine."
Paper: "OMG, WTF, Scissors!"
Scissors: "Rock is OP and Paper are QQers. We need PvP buffs."
inferno23 View Drop Down
  Quote inferno23 Quote  Post ReplyReply bullet Posted: 18 Jun 2009 at 1:42pm
50F wow thats cold. u must have some extreme air conditioning in your house mose normal air cconditioners wont make it that far down. unless u live up north somewhere
